November 7, 2022 at 10:16 am
#10843
Put a 12V 5W light bulb … or 2 of them inline … in the overload line. Replace the fuse with the lights.
If you have a light, then there is a problem.
I told you, that the motor has caps inside (!!!). Check it.
