Beovox S25
Beovox S25
Beovox S25 were compact speakers produced between 1977 and 1983 with linear phase reproduction, suitable for placement in a small bookshelf. Fitted with a 17cm woofer and a 5cm dome tweeter. Frequency range 65 – 18000 Hz. Volume 12,4 litres, Weight 4kg.
Type Number:6310, 6334
Release Date:1977, 1978, 1979
Designer:Jacob Jensen
Continuous load: 25 W
Music load: 40 W
Impedance: 4 – 8 ohms
Frequency response: +4 -8 dB 60 – 18,000 Hz
Sensitivity: 2.5 W
Gross volume: 12.4 litres
Woofer: 17cm
Tweeter: 5cm
Dimensions W x H x D: 22 x 41 x 15cm
Weight 4 kg
No downloads available.
