Beovox S22
Beovox S22
The smallest of the Uniphase range. These speakers were designed for use with the small music centres and less highly powered receivers in the B&O range. They were the same external design as the bigger models in the range but in a very compact box. Obviously they had limited bass reproduction but when placed correctly […]
They were the same external design as the bigger models in the range but in a very compact box. Obviously they had limited bass reproduction but when placed correctly could deliver excellent results.
Type Number:6308
Release Date:1977
Designer:Jacob Jensen
Description: Continuous load 22 watts
Music load 30 watts
Impedance: 4 – 8 Ohms
Frequency response +4 -8 dB 50 – 20,000 Hz
Sensitivity 6.5 W Net volume 8.4 litre
Gross volume 12.4 litre
Woofer: 16 cm
Tweeter: 2.5 cm
Dimensions W x H x D: 22 x 41 x 15cm
Weight 4 kg
No downloads available.
