BeoVox 3702
Beovox 3702 Type 6244 was a high-fidelity pressure chamber loudspeaker with high specifications and intermediate power handling capacity. It was a three-unit loudspeaker system, which means that the entire frequency range was covered by three separate units: bass, mid-range and tweeter or treble unit. Its frequency range was 40-20 000 Hz and it had a […]
It was a three-unit loudspeaker system, which means that the entire frequency range was covered by three separate units: bass, mid-range and tweeter or treble unit. Its frequency range was 40-20 000 Hz and it had a power handling capacity of up to 40 watts RMS or 75 watts music. Distortion was lower than 1% over the entire range.
The bass unit had a 20cm diameter speaker, the mid-range 8cm, the tweeter 2,5cm. Beovox 3702 met DIN high-fidelity norms.
Dimensions: height 50cm, width 25cm, depth 25cm
Type | Language | Type | |
Service Manual | EN | BeoVox 3702 Service Manual |
Photo Gallery
No gallery images.
