BeoVision ME 6000
Both Beovision LE 6000 and ME 6000 were equipped with Black Line picture tubes, which made the picture sharper. A toned-contrast screen in front of the tube enhanced the contrast level, making the picture more pleasant to watch. And Bang & Olufsen’s Colour Transient Improvement improved the sharpness of colour transitions, which eliminated irritating shadows. […]
Both Beovision LE 6000 and ME 6000 were equipped with Black Line picture tubes, which made the picture sharper. A toned-contrast screen in front of the tube enhanced the contrast level, making the picture more pleasant to watch. And Bang & Olufsen’s Colour Transient Improvement improved the sharpness of colour transitions, which eliminated irritating shadows. The powerful loudspeakers – under the screen on Beovision ME 6000 and to the side of the screen on Beovision LE 6000 – were based on the full-tone bass reflex loudspeaker system that gives sound power and fullness. Both were equipped with A2 and NICAM stereo systems.
They had Teletext that could be operated with the help of the remote control. The same remote control operated all video functions, if you connected a Bang & Olufsen video recorder.
Terminal included: Beolink 1000
Picture tube: 70cm Black Line-S, Black Matrix; Visible picture 66cm
Contrast screen: grey glass
VisionClear: auto cut-off
CTI
Teletext system: FastText, TOP, 6 languages
TV programmes: 60
Sound: stereo
Long-term max output: 2 x 20 W / 8 ohm
Speaker system: full range speakers
Power consumption/Minimum: typical 107 W / 6 W
TV tuner range/CTV system/Stereo decoder/Bilingual
5320 VHF, S, Hyper, UHF B/G/L PAL/SECAM A2
5323 UHF PAL I NICAM
5327 VHF, S, Hyper, UHF B/G PAL NICAM
Dimensions W x H x D: 65 x 67.5 x 46.5cm
Weight 39.3 kg
Connections: AV Link AV 1: 1 x 21-pin Datalink
AV 2 AV 2: Decoder 21-pin
Super VHS YC playback 4-pin
2 audio IN Phono sockets
Audio Out: 2 Phono sockets
Stereo headphones: jack socket 3.5mm
No downloads available.
Photo Gallery
No gallery images.
