BeoVision L 5500
Beovision L 5500 / 4500 – Alternative theatre A classic Bang & Olufsen TV has always been a good investment. However, if you didn’t need the advanced features that Beovision LX had to offer, the alternative TV was the ‘L’ range. It offered same design, same engineering, same quality, but different pricing and different colours.
CTV system: Multi-standard B/G/L (GB: PAL I)
Colour system: PAL/SECAM, NTSC A/V 4.43 MHz / 3.58 MHz
Picture tube (Visual picture): 70cm (66cm)
Picture tube system: flat square, Hi-Bri, In-Line 110 degrees
Contrast screen with metallised coating
Design: wide format cabinet
Cabinet: rosewood, grey metallic
Main features:
Operation Beolink 1000, one-way (prepared for two-way)
Sound centre balance: between BeoLab and Beovision speakers
Sound system: Built-in NICAM EU + A2 stereo decoder
Built-in NICAM EU + A2 dual language
TV tuner range: 46 – 855 MHz: VHF, S, Hyper, UHF
No. of TV programmes: 50
Satellite: prepared for BeoSat LM kit
No. of satellite programmes: 64
Signal/noise level: > 35 dB/1 Vpp and antenna signal > 1mV
Crosstalk between sources: > 45 dB / 5 MHz
Teletext FLOF, TOP, 5 alphabet, 6 alphabet (E)
Teletext memory 4 x 50 page nos
Station identification Via Teletext/station naming
Speaker system: 2 x bass reflex
Speaker units: woofer 2 x 10 cm, tweeter 2 x 5 cm
Crossover frequency: 2500 Hz
Long-term max. output power: 2 x 40 W / 8 ohms
Harmonic distortion < 0.5% at 15 W
Intermodulation: 50 dB weighted 50 mV (NICAM > 70 dB)
Frequency range, audio: 25 – 20,000 Hz +/- 1.5 dB
Power bandwidth: 25 – 20000 Hz
Treble control: +/- 8 dB /10000 Hz
Power supply: 220 – 240 V
Power consumption: 100 (75 – 165) W
Power consumption stand-by: 3 W
Dimensions W x H x D: 86 x 52 x 46cm
Weight: 40 kg
Connections: AV Link 2 x 21-pin SCART
Super VHS YC playback 4-pin socket
Audio Aux Link 7-pin socket
Power Link 2 x 8-pin sockets
External speakers 2 x 2-pin sockets
Motorized stand operation 4-pin socket
Aerial VHF – UHF 75 ohms coaxial socket
Stereo headphones: jack socket 6 mm
Link compatibility: Datalink
No downloads available.
Photo Gallery
No gallery images.
