Beovision L 2800
Beovision L 2800
Beovision L2800, L2500 These two television sets were for those who did not require the full range of hi-fidelity specifications offered by the Beovision LX2800 and LX2500 range. It was an ideal alternative and was designed with the same elegant shape and style. The L2800 and L2500 models provided the uncompromising standard of sound and […]
These two television sets were for those who did not require the full range of hi-fidelity specifications offered by the Beovision LX2800 and LX2500 range. It was an ideal alternative and was designed with the same elegant shape and style. The L2800 and L2500 models provided the uncompromising standard of sound and picture always associated with Bang & Olufsen.
Available in a modern grey finish, Beovision L series was not equipped with Teletext although this could be fitted as an optional extra.
Type Number:3721, 3726, 3732, 3799, 3722, 3725
Release Date:1986, 1987, 1988
Colour / Finish:Grey
CTV system (according to type)
Picture tube size: 70cm flat square (Visual picture size: 66cm)
Speaker system, stereo; 2 pressure chamber cabinets
Sound power output RMS: 2 x 15 W / 8 ohms
Harmonic distortion: 0.5%
Intermodulation: < 1 %
Frequency range: +/- 1.5 dB 25 – 20000 Hz
Power supply: 220 – 240 V
Power consumption: 95 W
Stand by: 3.5 W
Dimensions W x H x D: 86 x 52 x 46 cm
Weight: 43 kg
No downloads available.
