Beovision 9 – A state-of-the-art audio-video unit.
BeoVision 9’s digital sound processor is designed to drive the sound in up to 7.1 channels (the predominant format is still 5.1). You can connect up to 10 BeoLab speakers!
The “space ship” like form factor is driven by the Acoustic Lens Technology (ALT) that delivers a unique 180 degrees horizontal dispersion that maintain a constant tonal balance in all locations, both from direct and reflected sound. Another exclusive feature is the Adaptative Bass Control (ABC): at the press of a button the speaker measure the acoustic properties of the room and adapts its performance accordingly.
The BeoVision 9 is a complete home entertainment solution with a 50 inch HD plasma TV, a powerful center speaker (with ALT) and a built-in BeoMedia. It can be connected to other manufacturers set-top boxes, and has an integrated access to net radio, digital music, photos and the web. In addition, this intelligent device automatically adjusts the brightness and contrast to the ambient light using a dedicated sensor. You can navigate the TV guide, the music and photo files, control the sound volume, orient the display around its axis, all this from the Beo 4 remote control.
David Lewis, the designer, thinks that a TV is not an appealing object, so he succeeds in transforming it in a beautiful piece of furniture.
