Picture tube size 26″ – 66 cm
Cabinet Wood
Number of programmes 12 VHF – UHF
Range UHF 21 – 69
VHF 2 – 12
Picture tube 30 AX 110° in line self converging
Start time Approx. 5 sec.
Aerial impedance 75 ohms coaxial
Speakers
Woofer 4″ – 10 cm
Tweeter 2″ – 5 cm
Log Line system
Sound power output 14 watts
Harmonic distortion < 0.3 %
Intermodulation < 2.5 %
Frequency range +/- 1.5 dB 40 – 20,000 Hz
Power bandwidth 10 – 35,000 Hz
Signal-to-noise ratio > 55 dB
Bass control + 8 -5 dB / 100 Hz
Treble control + 9 -6 dB / 10,000 Hz
Power supply
180 – 265 volts
Power consumption 70 (65 – 130) watts
Dimensions W x H x D 77 x 49 x 45.5 cm
Weight 39 kg
