BeoVision 3000
BeoVision 3000
Beovision 3000 and 3300 had 50cm screens and were, at the time of the 1979 – 80 catalogue, Bang & Olufsen’s smallest colour TV sets. They were identical technically, except that Beovision 3300 had the ability to be controlled by remote control. However, it was only the size of the screens and the outer dimensions […]
However, it was only the size of the screens and the outer dimensions of the sets that were small, according to the catalogue. Inside, the technology was on a par with B&O’s biggest models, with the same advanced circuits that made the bigger 26″ models renown for their reliability and high quality levels. In order to secure the best sound reproduction, Bang & Olufsen included a large, forward-facing pressure chamber loudspeaker and a 6,5 watts RMS hi-fi amplifier, similar to those in audio setups.
The sets’ cabinets were finished in genuine wood veneers and lived up to the tradition of excellent Danish furniture workmanship.
Type Number:3537, 3538, 3539
Release Date:1978, 1979, 1980, 1981
Picture size: 51 cm
Cabinet: wood veneer
Features:
Cordless remote control
Start time Ca. 5 sec
Automatic cut off
AFC
Number of programs 8 VHF – UHF
Easy touch
Ranges VHF 2 – 12, UHF 21 – 69
Deflection angle: 110° in line
Aerial impedance: 75 ohms coaxial common VHF – UHF
Sound section:
Power output EMS: 1000 Hz 6.5 W
Distortion at specified output: < 0.8 %
Frequency response:
Amplifier: +/- 1.5 dB 60 – 15,000 Hz
Acoustical: +/- 10 dB 60 – 20,000 Hz
Power supply: 180 – 265 V
Power consumption 115 W
Stand by 1.5 W
Dimensions W x H x D: 62.5 x 40 x 38.5cm
Weight: 25.5kg
No downloads available.
