BeoVision 1500SJ
BeoVision 1500SJ
Type Number:340x
Release Date:1966, 1967
Aerial Impedance, VHF
UHF 75 ohms may be altered to 240 ohms by removing transformer 0972085/0507745
240 ohms only
Extension Speaker Connection 3-5 ohms
Gramophone Connection Prepared for gramophone (Beogram 1000, Type 5202) and crystal pick-up
Power Consumption (Measured with moving-iron instrument)
TV: 1100 mA (Approx. 245 W)
FM: 300 mA (Approx 70 W)
GR: 250 mA (Approx 55 W)
Power supply 220 V, DC or AC
Power Output 2.5 W
Tape Recorder Connection Prepared for diode output
Tuning FM tuner, 87.5 – 100.5 Mc/1: with AFC
VHF tuner with mechanical memory device: channels 2-11
UHF tuner with continuous tuning: channels 21-70
470-870 Mc/s
Valves PPC 189, VHF RF amplifier
PCF 86, VHF mixer
3 x EF 184, Video IF amplifiers
PCL 84, AGC and video output stage
A59 – 11W, Picture tube, 23 in. 114º
UCF 80 1, Noise inverter and 1st sound IF amplifier
UCF 80 2, AGC diode and 2nd sound IF amplifier
UCL 82, AF amplifier and output stage
PCF 80 3, Separator
PCL 85, Video output stage
ECC 81, Automatic line control
PCF 80 4, Line oscillator
PL 500, Line output
PY 88, Booster diode
DY 87, High voltage diode
UCC 85, FM RF amplifier and mixer
UCH 81, 2nd FM mixer
UM 84, Tuning indicator
Dimensions W x H x D, Beovision 1500 K: 60 x 49.3 x 39.6 cm
Dimensions W x H x D, Beovision 1500 SJ: 63.6 x 84.7 x 42.9 cm
Weight, Beovision 1500 K 28.5 kg
Weight, Beovision 1500 SJ 36 kg
No downloads available.
