Beosound Premiere
This is a premiere of something unseen and unheard. A sculptural form crafted from aluminium, that sculpts sound around you with fidelity and accuracy. Spatial. Seen differently. This is not only spatial sound. Itโs high-fidelity, faithful spatial sound. Hear every note, every word, every silence, where it was meant to be. Experience cinema and sound […]
This is not only spatial sound. Itโs high-fidelity, faithful spatial sound. Hear every note, every word, every silence, where it was meant to be. Experience cinema and sound at its most immersive. Get as close as possible to what the directors and mixing engineers intended.
Come closer
Beosound Premiere. A spatial soundbar for those who know the difference.
Whether itโs the first viewing of a film, or the unveiling of a long-anticipated album, Beosound Premiere brings life to sound.
A spatial audio experience, precision engineered to put you in the best seat in the house, recreates what the artist intended. Every beat authentic. Every silence intentional. Every note delivered with unwavering fidelity. The way itโs
meant to be.
A first-of-its-kind form: bold, sculptural, unapologetic. More than a soundbar, itโs a statement. Designed for those who hear the difference. Made to take centre stage.
| Year | Colour | Price |
| 2025 | Silver | ยฃ3,900 |
Included in the box
- Beosound Premiere
- HDMI cable
- LAN cable
- Mains cable
- Soundbar universal stand (combined wall & table solution)
- Soundbar wall plate
- Installation guide
- Important guide
- Drilling template for wall mounting of soundbar
- Torx screw driver
- Screws for bracket/stand
- Tool for removing speaker cover
- USB-C to AUX Adapter
- Polishing cloth
Recommended Room Size
- 10-45 mยฒ
Speaker Configuration
- 10 custom speaker drivers
- 4 x 4x3โ Racetrack drivers
- 2 x 2โ full range (front firing)
- 2 x 2โ full range (side firing)
- 1 x 1,5โ full range (up firing)
- 1 x 0,8โ tweeter
Amplifier
- 10 power amplifiers:
- 4 x 70 watts amplifiers for woofers
- 1 x 50 watts amplifier for tweeter
- 5 x 50 watts amplifiers for left/right/up firing/side firing full ranges
Frequency Range
- 34 Hz - 23,000 Hz
Maximum Sound Pressure Level (SPL)
- 102 dB (SPL)
Bass Capability
- 86 dB (SPL)
Advanced Sound Features
- Integrated 7.1.4 Dolby Atmos decoding and custom-tuned post-processing with proprietary True Image up- / downmixing algorithm.
- Wide Stage technologyโข
- Advanced Bass management system
- Adaptive Bass Linearisation (ABL) Thermal protection
RoomSense
- Manual speaker setup through the Bang & Olufsen App
Sound format HDMI
- Dolby Atmos supporting Dolby Digital TrueHD Dolby Digital plus 7.1 (including DD5.1) Dolby Atmos, Dolby MAT
- PCM 7.1 multichannel
- MPEG-2 AAC MPEG-4 HE-AAC
Customizable Sound EQ
- Presets available and fully customisable through the Bang & Olufsen App
Designer
- Bang & Olufsen Design team
Materials
- Aluminium Polymer
Dimensions
- Wall mounted: 932 x 160 x 133 mm
- Table stand: 932ย x 160 x 121 mm
Weight
- 8,5 kg
Cradle to Cradle certifiedยฎ
- Cradle to Cradle certifiedยฎ Bronze
Power consumption
- Typical: 80 W
Power
- 100-240V 50/60Hz mains cable
Bluetooth Version
- Bluetooth 5.4 (BLE and EDR)
WiFi
- Dual-Band Wi-Fi 5 (2.4 & 5 GHz) IEEE 802.11 b/g/a/n/ac
Streaming services
- Apple AirPlay 2 Bluetooth audio streaming HomeMedia Spotify Connect TIDAL Connect Deezer Connect QPlay2.0
Beolink Multiroom
- Seamlessly connect multiple Bang & Olufsen speakers to expand your music experience.
Beolink Surround
- Enjoy a true surround sound experience by connecting additional speakers to your setup through wired or wireless connections.
Physical Connections
- Soundbar inputs: 1 x HDMI eARC with passthrough 4K 120FPS / 8K 60FPS / 40Gbit with CEC input Analogue audio in via USB-C (3.5 mm passive jack adaptor required. B&O partno. 6271374 ) Ethernet switch with 3 x 1Gbit ports. (One port assigned for LG OLED TV connection for integrated control via Beoremote One and Bang & Olufsen App)
Remote control
- Integrated system control, including LG OLED TV Beoremote One BT Bang & Olufsen App for music streaming Beoremote Halo for music streaming
On-Device Controls
- Yes
Type | Language | Type | Date | Type | |
Installation Guide | EN | 2025 | Beosound Premiere Installation Guide | ||
Important Information | EN | 2025 | Beosound Premiere Product Important Information | ||
Product Data Sheet | EN | 2025 | Beosound Premiere Product Data Sheet |
Photo Gallery
