The Beosound Level wifi home speaker is our promise of designing future-proof products built to last. You go, Level follows. Bringing power, portability and connectivity wherever it’s needed. Standing up or laying down, it keeps your favourite songs by your side. Cradle to Cradle™ certified Beosound Level in the colours Natural and Gold Tone is […]
Beosound Level in the colours Natural and Gold Tone is the world’s first Cradle to Cradle Certified speaker (bronze level). Cradle to Cradle is the global standard for products that are safe, circular and responsibly made. That means you can easily upgrade it as technology evolves, if the battery runs out or if you want to change the colors. Next year or a decade from now. That’s part of future-proofing our products.
Music in any room? Bring it.
Coffee tables, work desks, bookshelves – Beosound Level settles right in. Designed to look and sound incredible anywhere, it seamlessly connects to WiFi while being free to move. Long day ahead? 16-hour battery life has you covered. Music in the kitchen? It’s splash resistant. Sync it up. Pick it up. And go.
Adaptable acoustics
Smart enough to play anywhere. Sleek enough to fit everywhere. Level adapts playback based on its position and surroundings, kicking out high-quality sound however you use it – standing up, laying flat or on the wall. Nothing gets in the way of the music, or the goosebumps.
Recommended Room Size
10-50 m²
100-500 ft²
Speaker Configuration
2 x 0.8″ tweeter
1 x 2″ full-range
2 x 4″ woofer
Amplifier
1 × 15 W class D for tweeter
1 × 30 W class D for full-range
2 × 30 W class D for woofer
Total: 105 W
Frequency Range
39 – 23.000 Hz
Maximum Sound Pressure Level (SPL) @1m
96 dB SPL
Bass Capability
79 dB SPL
Stereo Pairing
Pair two Beosound Level to enjoy a stereo listening experience.
Advanced Sound Features
Active Room Compensation
Adaptive Bass Linearization
Position-depended sound staging
Thermal Protection
Customizable Sound EQ
Presets available and fully customisable through the Bang & Olufsen App
Materials
Aluminium
Wood / Fabric
Polymer
Dust and Waterproof Rating
IP54
Dimensions (Width x Height x Depth)
34.8 W x 23 H x 5.6 D cm
Weight
3.3 kg
Power consumption
Typical: 25 W
Standby: 4,5 W
Power Supply
USB-C Power Supply
USB-C Cable with Easy Charge Solution
Battery Playtime
Up to 16 hours.
Bluetooth Version
Bluetooth 5.0
Bluetooth Codecs
Android: SBC
iOS: SBC, AAC
Wi-Fi
Dual band WLAN 2.4 & 5 GHz
IEEE 802.11 b/g/a/n/ac
Streaming services
Apple AirPlay
Spotify Connect
Google Cast
TIDAL Connect
B&O Radio
Deezer
QPlay 2.0
Beolink Multiroom
Yes
Physical Connections
1 x Ethernet
1 x Line-in/Optical combi-jack
1 x USB-C (Charging & Service Port)
1 x Easy Charge Solution
Remote controls
Bang & Olufsen App
Beoremote One BT
Beoremote Halo
On-Device Controls
Yes
Language
User Guide
EN
Beosound Level User Guide
Data Sheet
EN
Beosound Level Data Sheet
