BeoSound Explore
Extremely tough. Ready for anything. Beosound Explore is a rugged outdoor Bluetooth speaker thatโs crafted for adventure. Made to last Breaking new ground or walking the beaten path? Itโs all the same to the sturdy Beosound Explore. Inside the scratch-resistant, anodised aluminium shell, a vertical rib structure provides serious protection from bumps. We design and […]
Made to last
Breaking new ground or walking the beaten path? Itโs all the same to the sturdy Beosound Explore. Inside the scratch-resistant, anodised aluminium shell, a vertical rib structure provides serious protection from bumps. We design and build the aluminum shell of the speaker in Denmark as this is the only way we can ensure that it meets our strict requirements.
Travelling companion
Bring your music into the wild. Beosound Explore is designed to perform under extremes, and itโs just as intuitive to use as your other trusted gear. Clip it on your backpack or hang from your belt. Or lodge it in a cliff-side alcove. The rubber base keeps the speaker steady on most surfaces. Just grab it. And hit the trail.
Recommended Room Size
5-30 mยฒ
50-300 ftยฒ room
Speaker Configuration
2 x 1.8โ Full Range Drivers
Amplifier
2 ร 30 W class D for full-range
Total: 60 W
Frequency Range
56-22.700 Hz
Maximum Sound Pressure Level (SPL) @1m
91 dB SPL
Bass Capability
59 dB SPL
Stereo Pairing
Yes (between 2 Beosound Explores only)
Customizable Sound EQ
Presets available and fully customisable through the Bang & Olufsen App
Materials
Type II Anodised Aluminium
Fabric
Polymer
Dust and Waterproof Rating
IP67
Dimensions (Width x Height x Depth) (cm)
8.1 W x 12.4 H x 8.1 D cm
Weight (g)
637 g
Battery Playtime
Up to 27 hours
Charging Time
Approximately 2 hours
Bluetooth Version
Bluetooth 5.2
Bluetooth Codecs
SBC
Physical Connections
1 x USB-C (Charging)
On-Device Controls
Yes
Multipoint
Yes (Up To 2 Devices)
Certifications / Fast Pairing
Made for iPhone (MFI)
Google Fast Pair
Microsoft Swift Pair
Type | Language | Type | |
Quick Start Guide | EN | Beosound Explore Quick Start Guide | |
User Guide | EN | Beosound Explore User Guide | |
Data Sheet | EN | Beosound Explore Data Sheet |
Photo Gallery
No gallery images.
