BeoSound Edge
BeoSound Edge
BeoSound Edge is a compact and powerful wireless speaker, which through magical interaction, timeless design and cutting-edge acoustic innovation, offers a mesmerising listening experience. Active Bass Port. For the calm and for the storm. BeoSound Edge employs cutting-edge acoustic innovation to deliver a powerful and accurate listening experience. Through our latest patent for the world’s […]
Active Bass Port.
BeoSound Edge employs cutting-edge acoustic innovation to deliver a powerful and accurate listening experience. Through our latest patent for the world’s first Active Bass Port, the speaker provides perfect potent bass at high volumes and maintains accurate bass at low volumes.
Magical Interaction
Interacting with BeoSound Edge is enchanting. A push either way from BeoSound Edge’s centre of gravity controls the volume. Subtle resistance and damping make the instinctive rolling motion feel both luxurious and intuitive.
Music for you, me and everyone
With Directional Sound Control, BeoSound Edge allows the user to define the direction that the sound radiates. For instance, a room can be divided into an active listening area and a more passive listening area. Alternatively, the user can choose to blast true 360° room-filling sound from both sides of the speaker to fill the entire room.
Defy gravity
Keep your Beosound Edge casually on the floor or mount it on a wall as a stunning display. Enjoy the magical experience as the speaker rolls back into position as you pull or push the aluminium ring to adjust the volume.
A presence that adapts to you
Meet a speaker that feels your presence. As you approach, Beosound Edge comes to life, lightning up its touch-sensitive control interface through the aluminium surface. Simple and sophisticated.
Recommended Room Size
20-120 m² 200-1200 ft²
Speaker Configuration
1 x 10” dual coil woofer 2 x 4” midrange 2 x 3/4” tweeter
Amplifier
2 x 200 W class D for woofer (2 x 425W peak power) 4 x 100W class D for midranges and tweeters (4 x 200W peak power)
Frequency Range
12 – 23.200 Hz (Closed port) / 28 – 23.200 Hz (Open port)
Maximum Sound Pressure Level @1m
104 dB SPL
Bass Capability
92 dB SPL
Stereo Pairing
Pair two Beosound Edge to enjoy a stereo listening experience. Set up the stereo pairing through Google Home.
Advanced Sound Features
Active Bass Port Acoustic Placement Settings Adaptive Bass Linearization Beam Direction control (two sides) Thermal Protection
Customizable Sound EQ
Presets available and fully customisable through the Bang & Olufsen App
Materials
Highly polished aluminium body Black fabric covers Warm taupe covers
Weight
13 kg
Dimensions
50.2 W x 50.2 H x 13 D cm
Bluetooth Version
4.2
Wi-Fi
Wi-fi/WLAN 802.11 b/g/n/ac (2.4 GHz & 5 GHz)
Streaming services
Google Cast Airplay Beolink Multiroom Spotify Connect UPnP
Integrated music services
B&O Radio Deezer (incl Deezer HiFi) QPlay 2.0 (China Specific)
Inputs and outputs
1 x Mains Connection 1 x Line-in (analogue & digital combo) with sensing 1 x Ethernet 10/100 Mbit/s
Remote controls
Bang & Olufsen App Beoremote One BT Beoremote Halo
No downloads available.
