BeoSound Balance
Opulent, tactile materials crafted to last. Room-filling, omnidirectional sound. Beosound Balance is a sculptural statement with the smarts to match. Sculpted, not built Rooted in Scandinavian minimalism, Balance’s minimal design contrasts its stop-in-your-tracks sound. The materials? As rich and textured as your favourite song. From its sculpted solid base, to its Fibonacci patterned aluminium, this […]
Sculpted, not built
Rooted in Scandinavian minimalism, Balance’s minimal design contrasts its stop-in-your-tracks sound. The materials? As rich and textured as your favourite song. From its sculpted solid base, to its Fibonacci patterned aluminium, this is artistry of the highest order.
Note perfect. No compromise.
Smart. Loud. Beautiful. With every crisp note and beat, Balance builds a soundscape. Seven uniquely placed drivers disperse music in 360 degrees – clear acoustics up front, powerful enhancers at the back. From the table to the wall, your music fills the room. With punchy bass, clear mids, and pure acoustic bliss.
Play your way
Clear 360-degree sound tunes everyone into the music. Better yet: beamforming technology lets you direct the sound your way, for those moments when you don’t want to disturb others. Wherever the mood takes you, switch modes at the touch of a button.
Reads the room
Placement? Optional. Sound? Optimal. Balance is equipped with active room compensation, so it will precisely re-tune itself to make the most of any position. Place it on a shelf, table or counter – even against a wall – and enjoy a sound-to-size ratio that will leave you floored.
Recommended Room Size
10-80 m²
100-800 ft²
Speaker Configuration
1 x ¾” tweeter
2 x 2” full-range
2 x 3” full-range
2 x 5 ¼” woofer
Amplifier
1 x 50 W class D for tweeter
2 x 100 W class D for full-range
2 x 200 W class D for woofer
Total: 850 W
Frequency Range
26 – 23,000 Hz
Maximum Sound Pressure Level (SPL) @1m
104 dB SPL
Bass Capability
88 dB SPL
Stereo Pairing
Pair two Beosound Balance to enjoy a stereo listening experience.
Advanced Sound Features
Active Room Compensation
Thermal Protection
Adaptive Bass Linearization
Beam Width Control
Beam Direction Control (three sides)
Customizable Sound EQ
Presets available and fully customisable through the Bang & Olufsen App
Materials
Aluminium / Wood / Marble
Wool
Polymer
Dimensions (Width x Height x Depth) (cm)
20 W x 38 H x 20 D cm
Weight
From 7.2 kg (depending on colour variant)
Power consumption
Typical: 100 W
Standby: 4,5 W
Power Supply
Power supply built-in
Power Cable
Bluetooth Version
Bluetooth 5.0
Bluetooth Codecs
Android: SBC
iOS: SBC, AAC
Wi-Fi
Dual-Band Wi-Fi (2.4 & 5 GHz)
IEEE 802.11 b/g/a/n/ac
Streaming services
Apple AirPlay
Spotify Connect
Google Cast
TIDAL Connect
B&O Radio
Deezer
QPlay 2.0
Beolink Multiroom
Yes
Physical Connections
2 x Ethernet
1 x Line-in/Optical combi-jack
1 x USB-C
1 x Power
Remote controls
Bang & Olufsen App
Beoremote One BT
Beoremote Halo
On-Device Controls
Yes
Type | Language | Type | |
Quick Start Guide | EN | BeoSound Balance Quick Start Guide | |
User Guide | EN | BeoSound Balance User Guide | |
Data Sheet | EN | BeoSound Balance Data Sheet |
Photo Gallery
No gallery images.
