BeoSound 2 (2016)
BeoSound 2 (2016)
Captivating no matter where you place it, this powerful home speaker sounds as beautiful as it looks. Aesthetic functionalism Beosound 2 is designed for flexibility. Delivering the morning news from the kitchen table or playing discreetly from the living room floor. With its clean lines and small footprint, it has an adaptable design that fits […]
Beosound 2 is designed for flexibility. Delivering the morning news from the kitchen table or playing discreetly from the living room floor. With its clean lines and small footprint, it has an adaptable design that fits in everywhere in your home.
A seamless piece of beauty
Crafted in high-grade aluminium with incredible attention to detail. But our material choice go well beyond aesthetics. It also provides superior acoustic properties thanks to its material stiffness and seamless surfaces that eliminate any distortion of your sound.
The essence of control
Beosound 2 has a built-in proximity sensor that makes the control panel light up when your hand is hovering over the controls. The top of the speaker works as a minimalistic control panel. Simply tap one of the four favourite buttons to start one of your preferred radio stations or playlists, turn the wheel to adjust the volume and tap on one of the arrows to change tracks.
Active RoomSense
Beosound 2 works out where it is in the room to give you perfect playback, every time. Ensuring bass, mids and highs are never too overpowering or weak. Wherever you place it, it gives a standout performance. No muddiness. No fuzziness. Just pure, clean sound. As the artist intended.
Recommended Room Size
10-60 mยฒ
100-600 ftยฒ
Speaker Configuration
1 x ยพโ€ tweeter
2 x 2โ€ณ mid-range
1 x 5 ยผโ€ woofer
Amplifier
1 x 15 W class D for tweeter
2 x 15 W class D for mid-range
2 x 30 W class D for woofer
Total: 105 W
Frequency Range
33 โ€“ 23.400 Hz.
Maximum Sound Pressure Level (SPL) @1m
94 dB SPL
Bass Capability
84 dB SPL
Stereo Pairing
Pair two Beosound 2 3rd Gen to enjoy a stereo listening experience.
Advanced Sound Features
Active Room Compensation
Acoustic Lens Technology
Adaptive Bass Linearization
Thermal Protection
Customizable Sound EQ
Presets available and fully customisable through the Bang & Olufsen App
Materials
Aluminium
Polymer
Dimensions (Width x Height x Depth) (cm)
20 W x 43.1 H x 20 D cm
Weight
4.1 kg
Power consumption
Typical 15 W
Standby: 4,5 W
Power supply
Power supply built-in
Power cable
Bluetooth Version
Bluetooth 5.3
Bluetooth Codecs
Android: SBC
iOS: SBC, AAC
Wi-Fi
Dual-Band Wi-Fi (2.4 & 5 GHz)
IEEE 802.11 b/g/a/n/ac/ax
Streaming services
Apple AirPlay
Spotify Connect
Google Cast
TIDAL Connect
B&O Radio
Deezer
QPlay 2.0
Beolink Multiroom
Yes
Physical Connections
1 x Ethernet
1 x Line-in via USB-C
1 x Power
Remote controls
Bang & Olufsen App
Beoremote One BT
Beoremote Halo
On-Device Controls
Yes
Language
Quick Start Guide
EN
BeoSound 2 3rd Gen Quick Start Guide
User Guide
EN
BeoSound 2 3rd Gen User Guide
Data Sheet
EN
BeoSound 2 3rd Gen Data Sheet
