Beoplay H100
Ultimate over-ear headphones Beoplay H100 delivers immersive sound and luxurious design built to last the test of time. Advanced Dolby Atmos headphones with titanium drivers and next-level noise cancellation. Perfect for music, work, and travel. Every purchase includes an exclusive leather pouch to protect and carry your headphones in style. A headphone experience that reaches […]
A headphone experience that reaches back into decades of history to redefine your listening future. The possibilities? Many. The moment? Immersive.
No pressure. No distraction. Lost in the moment. This is when we find ourselves. And to do it, we just have to listen. Beoplay H100 brings back the clarity, so wherever we move, we feel moved.
Unbelievable sound.
The quality? Like never before. With custom titanium drivers housed behind elegant aluminium grills, these headphones deliver Hi-Res sound, all tuned by our in-house tonmeisters. The introduction of EarSense™ delivers a personal and unrivalled listening experience by tailoring the sound to your unique fit in real time.
Chaos: off. The moment: on.
To appreciate great sound, you need silence. That’s why Beoplay H100 has ten carefully configured studio-grade microphones, delivering our most advanced noise cancellation and transparency mode yet. Beoplay H100 also offers crystal clear call quality and reduced wind and background noise. So no matter how busy your world gets, you can stay focused.
Switch things up with ease.
Move from the music to the outside world in a twist. Use the carefully crafted haptic dial to enable TrueTransparency™ – a silky-smooth transition to your surroundings.
Make it natural with spatial audio
Take your listening experience to the next level and unlock a new dimension of immersion. Optimised for Dolby Atmos, state-of-the-art spatial audio processing and headtracking, Beoplay H100 delivers a more natural listening experience on any mobile device, for any type of content. So hit play and enjoy a multidimensional soundscape that extends beyond stereo.
Modular at heart.
Elements can be swapped out or serviced. The battery. The headband. The cushions. Even the drivers. One day, we believe all headphones will be designed like this. Intuitive. Long-lasting. Modular. So you can care for and make them like new again. And again. Beneath the surface lies a brand-new technology platform built to evolve, bringing new features as time goes on, so your musical moments will only get better. H100 is not just a beautiful headphone – it’s a meaningful one.
Intelligent and adaptive.
Beoplay H100 delivers an experience that feels instinctive and effortlessly natural. It pauses music, tunes you into the surroundings when you need it to and intuitively moves audio between your devices.
Crafted for effortless control.
The new scratch-resistant, hardened glass touch interface is silky smooth, both in feel and function. Together with precision haptic dials and tactile buttons, you have all the essential controls where you need them – right and left.
Moving beyond comfort.
Slip these on and enter a world of serenity. Thanks to the multiple layers of cushion foam, finely wrapped in knitted textile, the inner headband provides all day breathability and comfort. The lambskin leather sits gently against the skin and contributes to an experience that feels as good as it sounds.
Dimensions – WxHxD
Fully retracted:
198 x 196 x 56 mm (ear cushion flat down)
180 x 196 x 77 mm (ear cushion straight up)
Fully extended:
188 x 220 x 56 mm (ear cushion flat down)
188 x 210 x 77 mm (ear cushion straight up)
Leather pouch:
225 x 265 x 52 mm
Weight
Headphones: 375 g
Leather pouch: 350g
Material(s)
Aluminium
Titanium
Lambskin leather
Cowhide leather
Toughened glass
Polymer (not visible)
Fabric
Microphone(s)
4 Digital MEMS Voice microphones
4 MEMS Feed Forward microphones
2 Analogue Feedback Mic for
ANC/Transparency function
Battery
Replaceable Lithium-Ion batteries
– Capacity 2 X 520 mAh (Total: 1110 mAh)
Battery playtime
– Up to 32 hours (active Bluetooth and Active Noise Cancellation)
– Up to 30 hours (with Spatial Audio and Head Tracking)
– Up to 26 hours (when used for calls)
Charging time
Approximately 1 hour.
Quick charging time:
If the battery level is below 50%, charging for just 5 minutes will add up to 5 hours of battery life (depending on the charging adapter used).
Charger
5 V DC / 300 mA via USB-C
Power consumption
Typical 0.2 W
Standby: 0.002 W
Fast charge: 10.5 W
Operating conditions
Temperature 10 to 40°C
Humidity: 30 to 95% relative humidity
Controls
Buttons – Works for both sides:
Press: ANC/Transparency
Press and hold either button: Bluetooth pairing
Press and hold both buttons 10 seconds: Factory reset
Glass touch surface – Works for both sides:
Tap: Play & Pause / accept call
Swipe: Next & Previous / Reject & End call
Cover with palm: Quick Listen
Dial on right ear cup:
Media volume adjustment
Dial on left ear cup:
Transparency/ANC adjustment Indicator
Battery status:
White: 20-100% battery
Orange: 5-20% battery
Red: 0-5% battery
Product status:
Solid green: Connected to power, fully charged
Pulsing green: Software update in progress
Solid orange: Factory reset*
Pulsing orange: Connected to power, charging
Pulsing red: Microphones muted
Solid white for 3 seconds: Switched on, Bluetooth paired
Solid white for 1 second: Switching off
Pulsing white: Open for Bluetooth pairing
Proximity sensor: Yes
Loudspeaker(s): Electro-dynamic titanium driver w/ Neodymium magnets, 40 mm diameter
Frequency Range
10 – 20.000 Hz
10 – 40.000 Hz (hi-res mode)
Sensitivity: 103 dB SPL @ (1 kHz / -3dB FS)
Connections
Bluetooth
USB-C port
Bluetooth
Bluetooth 5.3
Multipoint:
2-device multipoint
3-device multipoint (expected via software update during 2025)
Sound codecs:
AAC codec
SBC codec
Wireless hi-res codecs (expected via software update during 2025)
Features
– Spatial Audio with Head Tracking
– Hi-Res support via USB Audio up to 24 bits 96 kHz
– EarsenseTM: compensation for an experience tailored to your fit
– 10 studio-grade microphones
– Outstanding Active Noise Cancellation
– TrueTransparencyTM: hear your surroundings as if you were not wearing headphones
– Quick listen: listen instantly to your surroundings
– Seamless multipoint: switch between devices smoothly
– Automatic switch on & off
– Intelligent audio & call routing
– Automatic play & pause
– Haptic dial for intuitive controls
– Customisable controls in the app
– Replaceable ear cushions and inner headband
– Scratch-resistant hardended glass interface
– Serviceable parts, including battery
Certifications
Google Fast Pair
Made for iPhone (MFi)
Microsoft Swift Pair
Optimized for Dolby Atmos
Hi-Res
Included
Beoplay H100 headphones
Leather pouch
Fabric USB-C to USB- C cable 1.25 m
Fabric USB-C to 3.5 mm audio cable 1.25 m
Quick start guide
Welcome card with NFC for quick and easy setup
Important guide
Available accessories
Leather pouch
Fabric USB-C to USB-C cable 1.25 m
Ear cushions (right and left)
Inner headband
Type | Language | Type | |
Data Sheet | EN | BeoPlay H100 Data Sheet | |
Important Information | EN | BeoPlay H100 Important Information | |
User Guide | EN | BeoPlay H100 User Guide | |
Quick Guide | EN | BeoPlay H100 Quick Guide |
Photo Gallery
