Beoplay Eleven
High-fidelity ANC earbuds Beoplay Eleven wireless earbuds boast improved noise cancellation and multipoint Bluetooth for a seamless listening experience anywhere. Hear. Stand out. Beoplay Eleven catches eyes as well as ears with a gem-like touch surface. A masterclass in precision craft. Fashioned from exclusive hardened glass, cool to the touch. Put your high-fidelity earbuds to […]
Hear. Stand out.
Beoplay Eleven catches eyes as well as ears with a gem-like touch surface. A masterclass in precision craft. Fashioned from exclusive hardened glass, cool to the touch. Put your high-fidelity earbuds to rest in your pearl-blasted aluminium case – though you’ll rarely want to.
A sound fit
Play with ease and wear with comfort. The soft in-ear piece, made of premium silicone that moulds to you. So light. So poised. So comfortable you’ll want to keep them in.
More music, less noise
Beoplay Eleven wireless earbuds boast our best noise cancellation technology in an earbud to date – further refined by our cunning pressure-relief outlets. Turn off your surroundings. And when you need it, our improved Transparency Mode brings you back with just a tap.
Clearer call quality
Large crowd or stubborn wind, it’s all the same to Beoplay Eleven. We’ve dialled up the calling experience with a slightly larger-than-usual microphone inlet, for clearer quality. Padded with a fine mesh that effectively filters wind from voice.
Powerful, portable sound
Portable sound should take you places. And power’s the kicker. This little jewel sports a 9.2mm driver in each earbud. In any environment.
Dust and waterproof
When it rains, Beoplay Eleven still delivers impeccable sound. An IP57-rated build means it’ll stay dry on the inside and blocks sand and particles.
DIMENSIONS
Earbud: 22.5 W x 34.8 H x 22.7 D mm
Charging case: 66.2 W x 48.2 H x 28.1 D mm
WEIGHT
Left earbud: 6 g
Right earbud: 6 g
Charging case: 53 g
MATERIALS
Aluminium
Polymer
Silicone
Tempered Glass
IDEAL FOR
Business
Commuting
Travel
Running & Fitness
Technical
LOUDSPEAKER
Neodymium Electro-dynamic,
9.2 mm diameter
IMPEDANCE
32 Ohm +/-3.2 @ 1KHz
EFFECTIVE FREQUENCY RANGE
20 – 22.000 Hz
SENSITIVITY
108 dB +/- 2 dB 1kHz @ 1mW (0.178V)
SAR
Max. power < 12 dBm
SOUND CODECS
aptXTM Adaptive
AAC
SBC
LED INDICATORS
Battery LED
MICROPHONES
Six MEMS, omni-directional
(beam directional for speech)
NOISE REDUCTION
Active Noise Cancellation
BATTERY PLAY TIME
Play time measured at 80dB
pink noise using AAC codec.
ANC on: 6 hours in earphones,
20 hours total
ANC off: 8 hours in earphones,
28 hours total
BATTERY TYPE
Rechargeable lithium-ion battery
Capacity right: 70 mAh
Capacity left: 70 mAh
CHARGING CASE
Capacity 380 mAh
2.5 charges with up to 20 hours playtime*
– one charge in earbuds and 2.5 additional
in a fully charged charging case in AAC
playback.
We recommend charging the case every 14
days – even when not in use!
POWER SUPPLY
5V USB charging by USB-C connector
CHARGING TIME
Earphones: 1 hour 30 minutes in charging
case for a full charge; charging for 20
minutes gives up to 1 hour 45 minutes
playback.
USB-C: 1 hour 45 minutes to fully charge
charging case
Wireless (Qi): 2 hour 15 minutes to fully
charge the case
CHARGE UNIT
USB-C charger 5V DC / 600 mA USB-C or
wireless Qi charger
BUTTONS
Touch controls in both earbuds for
controlling media, calls and Active Noise
Cancellation modes:
Other Information
DESIGNER
Thomas Bentzen + B&O Design Team
IN THE BOX
Charging case with wireless Qi receiver
Earbuds: Left and Right
USB-C/USB-C cable for charging, 0.5 m
COMPLY™ Medium size
Silicone tips, 4 sizes
Quick start guide
ACCESSORIES
A set of silicone ear gels
In all released colours:
Earbud either left or right
Charging case
Long USB cable 1,25 m
(USB-C to USB-C)
Bang & Olufsen App
(Apple App Store and Google Play Store)
Four sets of silicone ear tips: sizes XS, S, M, L.
FEATURES
Customizable ambient presets
Waterproof earbuds (IP57)
Secure fit for sports and fitness
Intuitive glass touch controls
First-class call quality with 6 built-in microphones
Adjustable own voice for calls
Multipoint connectivity for two devices
Beautifully crafted aluminium charging case
Up to 20 hours of total playtime with ANC
Type | Language | Type | Date | Type | |
Data Sheet | EN | 2410 | BeoPlay Eleven Data Sheet | ||
Important Information | EN | 2410 | BeoPlay Eleven Important Information | ||
User Guide | EN | 2410 | BeoPlay Eleven User Guide | ||
Quick Guide | EN | 2410 | BeoPlay Eleven Quick Guide |
Photo Gallery
