BeoPlay A9
BeoPlay A9
A statement in sound and sight. Beosound A9 makes every musical moment rich, detailed and immersive – all from a seamless circular shape that blends in beautifully or stands out confidently. Crafted from premium anodised aluminium, fabric and real oak, it’s a timeless work of art that can be customised to match your space and […]
Crafted from premium anodised aluminium, fabric and real oak, it’s a timeless work of art that can be customised to match your space and taste. When it’s time to dial up the volume, simply slide your finger gently across the top surface – and with a simple tap you can skip to the next or previous track and play/pause your music.
New degrees of detail
A9 stands strong on real oak legs, and delivers your music through acoustically calibrated covers. Ringed with precision-milled aluminium and backed by high-quality polymers, it forms an endless loop of engineering and art.
Customisable design
The shape is timeless, but the shade is yours to choose. A9 is a customisable centrepiece that adapts to your taste and space. Want a striking colour? You’re covered. Different legs? Swap them out. Personalise your speaker to chime with any room, and sing in any home.
Sculptural design
Beosound A9’s iconic shape is designed to be displayed. From afar, it’s a minimalistic masterpiece. Up close, the details shine. Just like your favourite furniture, it stands apart in any room. And if you prefer it on the wall, it rises to the occasion. Enjoy beauty from every angle, whether you press play or not.
Active room compensation
A9 works out where it is in the room to give you perfect playback, every time. Ensuring bass, mids and highs are never too overpowering or weak. Wherever you place it, it gives a standout performance. No muddiness. No fuzziness. Just pure, clean sound. As the artist intended.
Room-filling sound
When A9 plays, the whole room takes notice. Boasting volume that rivals much bigger speaker setups, it’s perfect for large spaces and get-togethers. Want a more immersive experience? Seamlessly connect A9 with other speakers to let the music flow through your home.
Sound mode Set.
Time to entertain? Dial up the bass. A moment to relax? Level things out, like when it’s time for your favourite podcast. The B&O app gives you customisable sound, right in the palm of your hand.
Recommended Room Size
15-100 m²
150-1000 ft²
Speaker Configuration
2 x ¾” tweeter
2 x 3″ mid-range
2 x 1 ½” full-range
1 x 8″ woofer
Amplifier
2 x 150 W class D for tweeter
2 x 200 W class D for mid-range
2 x 200 W class D for full-range
1 x 400 W class D for woofer
Total: 1500 W
Frequency Range
33- 23.000 Hz
Maximum Sound Pressure Level @1m
100 dB SPL
Bass Capability
95 dB SPL
Stereo Pairing
Pair two Beosound A9 5th Gen to enjoy a stereo listening experience.
Advanced Sound Features
Active Room Compensation
Thermal Protection
Adaptive Bass Linearization
Customizable Sound EQ
Presets available and fully customisable through the Bang & Olufsen App
Materials
Aluminium
Fabric / Wool
Wood
Polymer
Dimensions (Width x Height x Depth)
70.1 W x 90.8 H x 41.5 D cm
Weight
14.7 kg
Power consumption
Typical: 23 W
Standby: 8 W
Power Supply
Power supply built-in
Power Cable
Bluetooth Version
Bluetooth 5.3
Bluetooth Codecs
Android: SBC
iOS: SBC, AAC
Wi-Fi
Dual-Band Wi-Fi (2.4 & 5 GHz)
IEEE 802.11 b/g/a/n/ac/ax
Streaming services
Apple AirPlay
Spotify Connect
Google Cast
TIDAL Connect
B&O Radio
Deezer
QPlay 2.0
Beolink Multiroom
Yes
Physical Connections
1 x Ethernet
1 x Line-in via USB-C
1 x Power
Remote controls
Bang & Olufsen App
Beoremote One BT
Beoremote Halo
On-Device Controls
Yes
Language
User Guide
EN
BeoPlay A9 User Guide
Quick Start Guide
EN
BeoPlay A9 Quick Start Guide
Data Sheet
EN
BeoPlay A9 Data Sheet
Service Manual
EN
BeoPlay A9 MKIII Service Manual
