BeoMic BM6
BeoMic BM6
BM6 was a pressure-gradient ribbon microphone with full-frequency range, perfect figure-eight directional characteristic and a 3-position switch for speech, music and off. It had an international standard plug (DIN) and 150-ohm impedance – the internationally-accepted impedance for dynamic microphones in recording studios. Adding the BM7 microphone converted the BM6 into the BM5 mono/stereo microphone which […]
BM6 was a pressure-gradient ribbon microphone with full-frequency range, perfect figure-eight directional characteristic and a 3-position switch for speech, music and off. It had an international standard plug (DIN) and 150-ohm impedance – the internationally-accepted impedance for dynamic microphones in recording studios. Adding the BM7 microphone converted the BM6 into the BM5 mono/stereo microphone which could be use for stereo recordings according to the MS or AB method as desired.
Release Date:1961
Specifications: Dimensions 170mm high, 27mm diameter
Hum sensitivity -146 dB
Impedance 200 ohms
Response 30-13000 cHz +/- 2,5 dB
Sensitivity M position,85 dB below 1V/µbar
T position: 4 dB lower
No downloads available.
