BeoMaster 1000
Beomaster 1000 โ a compact all-transistor hi-fi 2 x 15 watt stereo amplifier equipped with a highly selective FL radio with extended FM band (to 108 MHz), 3-gang tuning capacitor and 4-stage intermediate-frequency amplifier, automatic control circuit which locks on FM stations and keeps them accurately tuned. It is prepared for single-transmitter stereo broadcasts, having […]
It is prepared for single-transmitter stereo broadcasts, having a B&O multiplex adaptor (stereo decoder); it is also equipped with a pilot lamp (โBeo-Beaconโ) which lights up when the receiver is tuned to a station transmitting an FM stereo programme.
The stereo amplifier, which plays both stereo and mono gramophone records, delivers no less than 2 x 15 watts of power output; piano-key speaker change-over switches which control two sets of stereo speaker systems, separate extra-efficient bass and treble controls; balance control for correct stereo sound distribution; physiologically compensated volume control (provides full balance at all volume levels throughout the tonal range); separate scratch and rumble filters; piano-key switching between mono and stereo reproduction; piano-key selectors for switching between the following types of operation: FM Broadcasting, FM Automatic Frequency Control; Tape Recorder; Gramophone 1; Gramophone 2.
Dimensions: 87mm high, 505mm wide, 24mm deep.
Choice of teak or Brazilian rosewood finish. Awarded the 1966 iF Prize for Industrial Designโ
Power output: 2 x 15 W continuous
2 x 20 W music power
Frequency range 30 โ 25,000 Hz- +/- 2 dB
Distortion <1% at 40 Hz โ 1 kHz โ 12.5 kHz / 15 W
Tone controls:
Bass control: + 10 dB โ 17 dB at 60 Hz
Treble control: + 12 dB โ 16 dB at 12.5 kHz
Built-in stereo decoder Only type 2317
Wave bands:
FM 88 โ 108 MHZ
RIAA amplifier: Built-in
Voltage: 110 โ 130 โ 220 โ 240 V
Power consumption 20 โ 120 W
Dimensions H x W x D: 9 x 51 x 24cm
Weight 5.5 kg
Connections: Gramophone 1
Gramophone 2
Tape
Aerial
Speakers 2 sets
Type | Language | Type | Type | |
User Guide | EN | BeoCenter 1000 User Guide | ||
Service Manual | EN | 2302, 2304 | BeoCenter 1000 Service Manual | |
Service Manual | EN | 2316, 2317 | BeoCenter 1000 Service Manual |
Photo Gallery
No gallery images.
