BeoLit 20
BeoLit 20
Big sound for any moment. Beolit 20 is a powerful top rated Bluetooth speaker with Qi wireless charging built-in. This is 240 watts you can feel. Beolit 20 may be portable, but it packs a punch that rivals much bigger speakers. A combo of powerful amplifiers and drivers โ€“ including a wideband woofer for rumbling […]
Beolit 20 may be portable, but it packs a punch that rivals much bigger speakers. A combo of powerful amplifiers and drivers โ€“ including a wideband woofer for rumbling lows โ€“ gives your music the presence it deserves. And with 360-degree sound dispersion, everyone can enjoy it.
Wireless charging pad
Place it. Charge it. Play it. At the top of Beolit 20, youโ€™ll find a built-in Qi wireless charging pad that keeps your compatible devices topped up wherever you go. You can even charge while you stream music, so thereโ€™s no need to pause the moment. Just enjoy it.
No hassle setup
Seriously powerful sound done simple: this is what Beolit 20 is all about. Switch it on, find it in the B&O app and start playing your favourite music. No extra cables, no complicated set up.
High-performance battery
Weโ€™ve pushed playtime to eight hours on a full charge by combining a large 3200 mAh battery with the latest in power efficiency. So youโ€™ll have the perfect soundtrack for any day out.
Fine-tune your listening
Deep, thumping bass. Crisp, clear highs. Balanced mids. Itโ€™s your music, and you can finetune your listening experience directly in the B&O app. The fully customizable equaliser and quick pairing feature lets you control how you listen with just a few taps.
Designer:Cecilie Manz
Recommended room size
10-50 mยฒ
100-500 ftยฒ room
Speaker Configuration
3 x 1 ยฝโ€ Full Range
1 x 5 ยฝโ€ Long-Stroke Wideband Woofer
2 x 4โ€ Passive Bass Radiators
Amplifier
1 x 35 W class D for tweeter
1 x 35 W class D for woofer
Total: 70 W
Frequency Range
37 โ€“ 20.000 Hz
Maximum Sound Pressure Level (SPL) @1m
93dB SPL
Bass Capability
77dB SPL
Stereo Pairing
Yes (Available between Beolit 20s and Beolit 17s)
Customizable Sound EQ
Presets available and fully customisable through the Bang & Olufsen App
Materials
Anodised Aluminium
Vegetable Tanned Leather
Polymer
Dimensions (Width x Height x Depth) (cm)
23 W x 18.9 H x 13.5 D cm
Weight
2.7 kg
Battery Playtime
Up to 8 hours
Charging time
Approximately 3 hours
Other
Wireless Qi Charging.
Charge your smartphones and other compatible devices wirelessly on the top surface.
Bluetooth Version
Bluetooth 4.2
Bluetooth Codec
AAC
SBC
Physical Connections
1 x USB-C (Charging)
1 x Line-In (3.5mm jack)
On-Device Controls
Yes
Language
Quick Start Guide
EN
Beolit 20 Quick Start Guide
User Guide
EN
Beolit 20 User Guide
Data Sheet
EN
Beolit 20 Data Sheet
