BeoLab 19
BeoLab 19
Beolab 19 delivers exceptional bass to enhance the mood and depth of cinematic experiences by channeling the raw impact of its stunning power. To top it off, the freedom of wireless simplicity and the ability to compensate for physical placement in the room allows you to find the perfect spot for the Beolab 19 in […]
Beolab 19 delivers exceptional bass to enhance the mood and depth of cinematic experiences by channeling the raw impact of its stunning power. To top it off, the freedom of wireless simplicity and the ability to compensate for physical placement in the room allows you to find the perfect spot for the Beolab 19 in your home.
Reach peak performance
Add extra depth and uncover new details in films and music with this progressive subwoofer. It’s not just the distinctive design that gives Beolab 19 its impact. Every technical detail is engineered to capture the precise emotions in even the lowest frequencies.
Accurate wireless sound
You can place Beolab 19 anywhere you want. The subwoofer is equipped with the innovative wireless WiSA technology that brings unprecedented levels of stability and precision to your home audio setup and seamlessly connects with all WiSA-compliant speakers and TVs.
Surprising symmetry
Where most other subwoofers are designed with unpleasing aesthetics, Beolab 19 brings its own distinctive style to your surroundings. The geometric form and solid aluminium exterior produce a sculptural character, true to its forceful nature.
Designer:Jakob Wagner
Power Amplifiers (per speaker): 2 x 160 watt, Class D, woofers
Speaker Drivers (per speaker): 2 x 8” woofers
Bass Capability @1m: 98 dB SPL
Frequency Range: 18 – 1,200 Hz
Power Supply
Power supply built-in
Power cable included
Advanced Sound Features
Acoustic Balance Principle
Thermal Protection
Adaptive Bass Linearization
Acoustic Placement Settings
Low-pass Filter Adjustment
Phase Setting (0/180)
Connections
1 x Powerlink (RJ45)
1 x RCA (L/R)
Wireless Powerlink
Wireless Power Link (24 bit / 48 kHz)
WiSA (24 bit / 48 kHz)
Product dimensions W x H x D: 34.8 x 33.4 x 29.3 cm
Weight: 15.4 kg
Placement: Floor
Recommended Room Size: 10 – 50 m²
Language
Data Sheet
EN
BeoLab 19 Data Sheet
Service Manual
EN
BeoLab 19 Service Manaul
