BeoLab 18
BeoLab 18
The culmination of over 25 years of design and innovation, the Beolab 18 introduces a refined symbiosis of form, craftsmanship, and performance Inspired by the legendary Beolab 8000 loudspeaker, it honours a classic silhouette with new heights of performance and flexibility. Beolab 18 requires just a power cable to unleash multi-channel wireless audio throughout the […]
The culmination of over 25 years of design and innovation, the Beolab 18 introduces a refined symbiosis of form, craftsmanship, and performance Inspired by the legendary Beolab 8000 loudspeaker, it honours a classic silhouette with new heights of performance and flexibility. Beolab 18 requires just a power cable to unleash multi-channel wireless audio throughout the space.
Discover the impeccable experience of wireless Bang & Olufsen sound. Needing just a single power cable to perform, the speaker brings incredible opportunities to unleash the joy of multi-channel wireless audio in your home.
Any spot is the right spot
The slender speaker leaves a surprisingly small footprint. It’s designed to fit and blend in almost anywhere, regardless if you are looking for a freestanding floor speaker, want to tuck it in a corner or hang it on your wall like an artwork.
A poetic expression of sound
The aluminium pillar balances almost magically on its pointed base, while the crafted wooden lamellas appear to be fanning out the sound across your room in concert with the acoustic lens on top. Meet design and engineering in perfect harmony.
Design-driven innovation
Beolab 18 is a stunning work of design engineering with audio performance at its heart. The acoustic lens evenly distributes the upper frequencies in a 180-degree horizontal arc, delivering superior sound experiences across your room, not just in front of your speaker.
All the little big things
Behind its beautiful exterior, Beolab 18 is filled with advanced audio technologies. Adaptive Bass Linerisation automatically adjusts the bass performance to what you are playing, while the room adaptation feature optimises the sound based on your speaker’s placement.
Power Amplifiers (per speaker)
1 x 160 watt, Class D, tweeter
1 x 160 watt, Class D, woofer
Speaker Drivers (per speaker)
1 x 3/4” tweeter
2 x 4” woofer
Maximum Sound
Pressure Level @1m: 107 dB SPL (pair)
Bass Capability @1m: 83 dB SPL (pair)
Frequency Range
39 – 23,500 Hz
Power Supply
Power supply built-in
Power cable included
Advanced Sound Features
Acoustic Lens Technology
Thermal Protection
Adaptive Bass Linearization
Acoustic Placement Settings
Product dimensions W x H x D
On the floor: 20 x 132.4 x 20 cm
Wall mounted: 15.5 x 132.6 x 13.5 cm
Weight
9.2 kg (without base or wall bracket)
Placement
Floor
Wall mounted
Recommended Room Size
10 – 30 m²
Connections
2 x Power Link (RJ45)
Wireless Power Link (24 bit / 48k)
1 x RCA (L/R)
1 x TOSLINK:
in: Sample rate 32k, 44.1k, 48k, 96k/PCM16-24 bit
out: Sample rate 48k/PCM 24 bit
Wireless Powerlink
Wireless Power Link (24 bit / 48 kHz)
WiSA (24 bit / 48 kHz)
Streaming Formats With Beosound Core
Chromecast built-in
Apple AirPlay 2
Bluetooth Audio Streaming
Spotify Connect
No downloads available.
