BeoLab 17
BeoLab 17
BeoLab 17 is a solid, impressive loudspeaker with powerful sound that punches way beyond its actual size. Its tight, striking geometry exudes character with myriad expressions. Featuring Immaculate Wireless Sound, BeoLab 17 enables you to enjoy wireless music in unsurpassed detail – while giving you freedom and flexibility to open up exciting new options for […]
and flexibility to open up exciting new options for your home dêcor.
SOUND
The little big wonder
Beolab 17 lets you enjoy wireless music in unsurpassed detail. With Adaptive Bass lineariation, the speaker automatically optimises its bass performance to the way you play your music. Room adaptation ensures harmonious sound no matter where you place your speakers.
DESIGN
A geometric work of art
The Beolab 17 speaker is designed with an innovative triangular body that opens a myriad of placements options. There is no dedicated top, bottom or sides on the cabinet. It all depends on the way you decide to use it.
PLACEMENT
Clear sound in all the right places
Hang it on your wall, place it on a shelf or choose between two different floor stands. The versatile placement options bring exciting new ways to living with beautiful music, regardless if you need a classic set of stereo speakers or speakers for your home theatre.
MATERIALS
A crafted frame for your music
This compact high-end speaker is made from a single piece of beautifully crafted aluminium. Unlike most other speakers, the fabric speaker cover is placed inside the aluminium body, which creates a circular frame for the colour of your choice.
Recommended Room Size
50 m²
500 ft²
Speaker Configuration
1 x 3/4″ tweeter
1 x 6″ woofer
High frequency driver: ¾” dome drivers with off-set placement behind the fabric front to give optimal performance regardless of how you turn the speaker
Amplifier
1 x 160 watt class D tweeter
1 x 160 watt class D woofer
Frequency Range
31 – 24,000 Hz
Maximum Loudness @1m (SPL)
106 dB SPL
Bass Capability
90 dB SPL
Advanced Sound Features
Adaptive Bass Linearization
Acoustic Placement Settings
Thermal Protection
CONNECTIVITY
Wi-Fi
Wireless Power Link (24 bit / 48 kHz)
WiSA (24 bit / 96 kHz)
Inputs an outputs
2 x Power Link (RJ45)
1 x RCA (L/R)
1 x Optical
In: Sample rate 32k, 44.1k, 48k, 96k/PCM16-24 bit
Out: Sample rate 48k/PCM 24 bit
Power supply
100-240V 50/60Hz mains cable
Weight
8.5 kg
Dimensions
On floor stand: 25 W x 71.9 H x 24.8 D cm
With wall bracket: – 0° 23.6 W x 32 H x 15 D cm
With wall bracket: – 20° 24.9 W x 32 H x 14.6 D cm
On floor base: 24.9 W x 71.9 H x 35 D cm
On end cap: 32 W x 25 H x 13.4 D cm
Language
Data Sheet
EN
BeoLab 17
Data Sheet
Service Manual
EN
BeoLab 17 Service Manual
