BeoGram CD 6500
BeoGram CD 6500
If you wanted to indulge yourself with the finest sound quality then you’d do no better than listening to your favourite pieces of music on Bang & Olufsen’s Beogram CD 6500. Beogram CD 6500 was a replacement for its predecessor, Beogram CD 5500. It played both 12cm and 8cm compact discs, and housed sophisticated and […]
It played both 12cm and 8cm compact discs, and housed sophisticated and advanced digital technology. And it offered sound reproduction which would satisfy even the most demanding of listeners.
Beogram CD 6500 could be used as part of the Beosystem 6500 hi-fi system.
Type Number:5136, 5137, 5138, 5139, 5140
Release Date:1989, 1990, 1991, 1992
Designer:Jacob Jensen
Colour / Finish:Black, Silver, White
Frequency range: 3 – 20,000 Hz +/- 0.3 dB
Signal-to-noise ratio: > 100 dB / 110 dB A-weighted
Dynamic range: > 96 dB
Harmonic distortion incl. noise: < 0.0025% at 0 dB
101 dB
Channel difference: 20,000 Hz > 50 dB
Phase error between L & R 0 degree at 20 – 20,000 Hz
Output analogue: 1.3 V RMS at 0 dB
Output, signal: For digital equipment
Power supply:
5136: 220 V
5137: 240 V
5138: 100 V
5139: 120 V
5140: 240 V
Power consumption 23 W
Weight 6.3 kg
Link compatibility: Data Link
Language
User Guide
EN
BeoGram CD 6500 User Guide
