BeoGram CD 3300
It’s a fact that not all compact disc players are ideal for all types of music. Some of them seem to highlight certain parts of the frequency range. But you can be confident that Bang & Olufsen’s CD players never discriminate between rock and roll and classical. They smooth over faults in the CD very […]
It’s a fact that not all compact disc players are ideal for all types of music. Some of them seem to highlight certain parts of the frequency range. But you can be confident that Bang & Olufsen’s CD players never discriminate between rock and roll and classical. They smooth over faults in the CD very cleverly too, because not all compact discs are perfect. So it’s just as well that Bang & Olufsen CD players are!
Beogram CD 3300 was part of Beosystem 3300 although it could have been used as a stand-alone item.
Frequency range: 3 – 20,000 Hz +/- 0.3 dB
Signal-to-noise ratio: > 96 dB / 100 dB A-weighted
Dynamic range: > 96 dB
Harmonic distortion incl. noise < 0.003% at 0 dB;
94 dB
Channel difference: 20,000 Hz > 50 dB
Phase error between L and R 0 degree at 20 – 20,000 Hz
Output analogue: 2 V RMS at 0 dB
Power supply:
5141: 220V
5142: 240V
5143: 120V
5145: 240V
Power consumption: 30 W
Dimensions W x H x D: 42 x 7.5 x 31cm
Weight: 4.9 kg
Type | Language | Date | Type | Type | |
User Guide | EN | EN | EN | BeoGram CD 3300 User Guide | |
Service Manual | EN | 01-87 | 5141, 5142, 5143, 5144, 5145 | BeoGram CD 3300 Service Manual | |
Service Manual | EN | EN | PCB 30 | BeoGram CD 3300 Service Manual |
Photo Gallery
No gallery images.
