BeoGram 9000
If you valued your record collection, rest assured that it would have been in safe hands with Beogram 9000. The electronically controlled tangential arm played the record at the exact angle that the original master was cut, giving a precise reading of the signals in the groove. The delicate MMC 4 cartridge had a stylus pressure of […]
If you valued your record collection, rest assured that it would have been in safe hands with Beogram 9000. The electronically controlled tangential arm played the record at the exact angle that the original master was cut, giving a precise reading of the signals in the groove. The delicate MMC 4 cartridge had a stylus pressure of only 1,2g, minimising friction between record and cartridge.
Beogram 9000 – Beocenter 9000’s record player
There was built-in protection against vibration too, with the special chassis suspension and a short, rigid tone arm. Which all added up to longer life for your record collection as well as superior sound. Like the rest of Beocenter 9000 the record player could be operated through the remote control.
Speeds: 33 – 45 rpm
Speed deviation: < +/- 0.2 %
Wow and flutter, DIN: 80 dB
Power consumption: < 10 W
Weight 5.3 kg
Type | Language | Type | Type | |
User Guide | EN | BeoGram 9000 User Guide | ||
Service Manual | EN | 5961, 5963, 5964, 5965 | BeoGram 9000 Service Manual |
Photo Gallery
No gallery images.
