BeoGram 2000 (1983)
This radial-tracking record deck had a lightweight turntable (only 400g) to minimise torque at starting. The automatic cueing system was also very fast-acting, so it was only a matter of a few seconds between touching the PLAY control and hearing the music. The tone arm had built-in anti-skating and carried the MMC 4 pickup, ensuring accurate tracking […]
The tone arm had built-in anti-skating and carried the MMC 4 pickup, ensuring accurate tracking and excellent sound quality. Normal PLAY and STOP functions were entirely automatic and could be operated with the lid closed; manual buttons for playing non-standard discs were located on the deck plate. In addition to automating the setting of correct speed and cueing position for each record, the Beogram’s built-in microcomputer allowed a REPEAT function, which could be programmed for up to 7 plays of the same record.
Drive was provided by a tacho-controlled DC motor via a flat rubber belt, so turntable speed was always accurate and could not be affected by fluctuations in the mains supply.
When used with Beomaster 2000, an electronic data-link allowed Beogram 2000 to be operated by the Beomaster’s controls. Beogram 2000 could also be made up as part of the Beosystem 2000, when linked together with other compatible Bang & Olufsen products.
Speeds: 33 - 45 rpm
Speed deviation < +/- 0.2 %
Wow and flutter DIN 75 dB
Rumble DIN unweighted > 55 dB
MMC 4 cartridge
Recommended tracking force 12 mN / 1.2 g
Power supply:
5821-5825: 190 - 265 (90 - 130) V
2823: 120 V
Power consumption: < 10 W
Dimensions W x H x D: 42 x 8 x 32.4cm
Weight 6 kg
Link compatibility: Data Link
Type | Language | Date | Type | Type | |
User Guide | EN | BeoGram 2000 User Guide | |||
Service Manual | EN | 5811, 5813, 5814, 5815 | BeoGram 2000 Service Manual | ||
Service Manual | EN | 5240 | BeoGram 2000 Service Manual | ||
Supplement Service Manual | EN | 10-84 | BeoGram 2000 Supplement Service Manual |
Photo Gallery
No gallery images.
