BeoGram 1001
BeoGram 1001
The Beogram 1001 was a slightly updated Beogram 1000. The major change which you may notice is the lack of the name on the front of the cabinet. You may then notice the lack of a 78 rpm setting and finally the cartridge changed to the SP14 rather than the SP6/7. Performance was however just […]
The Beogram 1001 was a slightly updated Beogram 1000. The major change which you may notice is the lack of the name on the front of the cabinet. You may then notice the lack of a 78 rpm setting and finally the cartridge changed to the SP14 rather than the SP6/7. Performance was however just the same – surprisingly good but poor isolation from external vibration. The lid was just as useless as before and did not allow it to be left on during playback.
Type Number:5101
Release Date:1973, 1974
Colour / Finish:Rosewood, Teak, White
Speeds: 45 and 33 rpm., with provision for vernier adjustment of speed
Rumble Better than 55 dB (DIN B)
Wow and flutter +/- 0.15 % peak value
Pickup arm: ST/L 15°
Pickup SP 14 A
Recommended tracking force 1.5 – 2.5g
Voltage: 220 volts AC
Power consumption 10 W
Dimensions W x H x D 36 x 11.5 (approx. 12.5cm with dust cover) x 31cm
Weight 6 kg
Language
N/A
English
BeoGram 1001
View
