BeoCord VX5500
BeoCord VX5500
A special Bang & Olufsen feature was ‘spontaneous videotaping’. If you wanted to record the programme you were watching it was simply a matter of pressing ‘record’ twice on the remote control handset – and the VCR would automatically find the right channel and start taping. You could with Beocord VX5500 play back in slow […]
You could with Beocord VX5500 play back in slow motion all the way down to still. You could use the picture-in-picture module with the VCR and the B&O TV on which you had it linked up to and it was also possible to keep your video tapes organised. By using a graphic ‘notebook’ you could name every video tape you record. Then you use the Beolink 5000 or Beolink 1000 terminal to simply order up the number of your recording.
Type Number:4567, 4561, 4560, 4535, 4569, 4562, 4568, 4566, 4536, 4563
Release Date:1991, 1992, 1993
Designer:David Lewis
Colour / Finish:Black, White
Cassette format: VHS
Tape heads 3 video, 2 Hi-Fi audio
TV channels VHF band 46 – 300 MHz
Hyper-band 300 – 470 MHz
UHF channels 21 – 69
Number of programmes 99
Play channel UHF 37 (adjustable 30 – 39)
Sound, compatible normal/Hi-Fi Stereo, Hi-Fi sound
Decoder TV stereo
A2 built-in (Not in type 4532/38)
Decoder bilingual sound A2 built-in (Not in type 4532/38)
Max. playing time, audio/video
4 hours, E-240
Max. playing time, audio only 8 hours, E-240
Fast forward and rewind: approx. 6 min. E-240
Counter Tape counter, remaining time
Time programming 8 programmes up to a year
Slow motion video tape Variable speed
Still picture video tape Noiseless
Search forward: 5 x normal speed
Search rewind: 5 x normal speed
Index search Track no., digital picture index
Tape speed VTR 23.39 mm/sec.
Tape speed ATR 11.7 mm/sec.
Recording system HQ
Frequency range black/white: 2.5 MHz
Signal-to-noise ratio luminance 47 dB
Signal-to-noise ratio chrominance amplitude modulation 38 dB
Pulse modulation 50 dB
Placement min. height: 22 cm
Dimensions: W x H x D 54 x 8.5 x 30 cm
Weight: 9.1 kg
Connections: RF in 75 ohms
RF out 75 ohms
AV Link 21-pin
AV decoder 21-pin
Camera pause Jack
Remote sensor Jack
Headphone Jack
Microphone Jack
Language
User Guide
EN
BeoCord VX5500 User Guide
Setup Guide
EN
BeoCord VX5500 Setup Guide
