Beocord VHS 91 was a genuine hi-fi sound recorder as well as a high quality VCR. It not only gave 4 hours of video recording, but also 8 hours of stereo sound with a level of quality approaching that of compact disc..
Equipped with Bang & Olufsen’s advanced HX Professional recording system and Dolby B Noise Reduction, Beocord VHS 91 could be used for recording directly from the television and stereo sound from your hi-fi during simulcasts. And as a hi-fi sound recorder, it could also be connected to the Beolink® system to take music all over your house. When connected to your B&O TV, VHS91 could be controlled by the Video Terminal remote control.
BeoCord VHS91 Product Details
Type Numbers
4491 (1985 - June 1986)
4492 (GB) (1985 - Oct 1986)
4495 (MULTI, S-CH) (1985 - Oct 1986)
4493 (OSCAR) (1985 - March 1987)
Designer
Please let us know
Manufactured
1985 - 1986
Colour Options
Please let us know
BeoCord VHS91 Product Specification
Description: TV system B/G VHF + UHF( 4491) I UHF (4492) B/G all Band tuner + UHF (4493) Colour system PAL/SECAM modified (4491) PAL (4492) PAL/SECAM modified (4487) Cassette format VHS Remote control system Built-in for Video terminal Tape heads 3 video, 2 Hi-Fi audio Sound, compatible normal/Hi-Fi Stereo, Hi-Fi sound Stereo decoder Stereo an bilingual, TV-broadcasts (4493) Max. playing time, audio/video 4 hours, E-240 Max. playing time, audio only 8 hours, E-240 Fast forward and rewind Approx. 6 min. E-240 Step advance 1 frame Search forward 4 x normal speed Search rewind 4 x normal speed
Counter Electronic, 4 digits TV channels VHF 2-12, UHF 21-69 Play channel UHF 37 (adjustable 30-39) Number of programmes 39 Time programming 3 programming up to 14 days in advance, or daily, + 1 weekly
Power supply 220V (4491) 240V (4492) 220V (4493)
Relative humidity 30-80 % Dimensions W x H x D 40 x 10.5 x 37.5 cm Weight 10 kg
Connections: A/V, audio/video socket 21-pin LINE IN, audio 7-pin Datalink 50 mV/50 kohms LINE OUT, audio 7-pin Datalink 800 mV/600 ohms
