BeoCord VHS82.2
BeoCord VHS82.2
A mildly updated VHS82 designed to work with the new range of MX televisions.
Type Number:4550, 4552, 4553, 4554, 4555, 4557, 4558
Release Date:1988, 1989
Colour / Finish:Black, Grey, Red, White
Description: TV system B/G All band + UHF (4550, 4554, 4558)
I UHF band (4552)
B/G All band + UHF (4553, 4557)
Colour TV PAL
Cassette format VHS
Remote control system Via Beovision LX 2800/MX 2000
Sound, compatible normal/Hi-Fi Stereo, Hi-Fi sound
Stereo decoder Stereo and bilingual TV
VPS, Video Programming System No (4510)
No (4512)
Yes (4513, 4517)
Max. playing time, audio/video 4 hours, E-240
Max. playing time, audio only 8 hours, E 240
Fast forward and rewind Approx. 5 min. E-240
Still picture Max. 8 minutes
Step advance Typically 4 frames (2-10)
Play reverse Normal speed
Search forward 3 and 7 x normal speed
Search rewind 7 x normal speed
Counter Electronic, 4 digits
TV channels All band: VHF 2-12, S channels 105-168, 231-287 MHz, UHF 21-69, (4550, 4554, 4558)
UHF 21-69 (4552)
All band: VHF 2-12, S channels 105-168, 231-287 MHz, UHF 21-69, (4553, 4557)
Play channel
UHF 37, (adjustable 30-40)
Number of TV programmes 35 + AV
Time programming Max. 2-4 programmes: up to 31 days, in advance, daily or weekly
Programmed end time Intervals of 30 min.
Power supply
240V (4550, 4554, 4558)
220V (4552)
240V (4553, 4557)
Placement, min. height
20 cm
Ambient temperature +10/+35 degrees
Relative humidity 30/80%
Dimensions W x H x D 42 x 8.4 x 32.5 cm
Weight 7.5 kg
Connections: A/V, audio/video socket 21-pin
Audio IN/OUT sockets 4 Phono plugs
RF IN 75 ohms
RF OUT 75 ohms
No downloads available.
