BeoCord VHS66
BeoCord VHS66
In the crucial quiet passages you heard only the sound of silence from the mono Beocord VHS66. The HX Professional recording system gave more ‘headroom’, enhancing the definition of high, delicate sounds, and Dolby B Noise Reduction cut down on hiss and noise. Features: Dimensions (WxHxD): 48 x 10,5 x 36cm 4 hours of recording/playback […]
Features:
Type Number:4485,4486,4487
Release Date:1985, 1986
TV system B/G VHF + UHF( 4485)
I UHF (4486)
B/G all Band tuner + UHF (4487)
Colour system PAL/SECAM modified (4485)
PAL (4486)
PAL/SECAM modified(4487)
Cassette format VHS
Remote control system Video terminal
Tape heads 3 video
Sound Mono
Sound recording system HX PRO
Max. playing time 4 hours, E-240
Fast forward and rewind Approx. 6 min. E240
Step advance 1 frame
Search forward 4 x normal speed
Search rewind 4 x normal speed
Counter Electronic, 4 digits
TV channels VHF 2-12, UHF 21-69
Play channel UHF 37 (adjustable 30-39)
Number of programmes 39
Time programming 3 programming
Power supply
220V (4485)
240V (4486)
220V (4487)
Placement, min. height: 22 cm
Ambient temperature +5/40 degrees
Relative humidity 10-75 %
Dimensions W x H x D 48 x 10.5 x 36 cm
Weight 9.5 kg
Connections: A/V, audio/video socket 21-pin
LINE IN/OUT, audio socket 7-pin
RF IN 75 ohms
RF OUT 75 ohms
No downloads available.
