Posted on
BeoCord V8802
Bang & Olufsen BeoCord V8802
If your choice of TV viewing included video, the Beovision Video Terminal supplied with your Beovision 5100, 7100 or 8100 (or Beovision models 5500, 7700, 8800 and 9000 featured in the 1982 Autumn catalogue) could also be used to operate the Beocord V8802 video cassette recorder.
There were two types of video stand available, specially designed to accommodate any Bang & Olufsen VCR and combine them into a complete video system that was easy to install, easy to live with and a joy to use.
Beocord V8802 used the technical superiority of the V2000 format to guarantee top-quality recording and playback on economical flip-over cassettes. The 2×4 hour flip-over cassettes gave you 8 hours of recording time in one tape, which worked out cheaper in cost-per-minute terms than any other video format.
Microcomputer technology gave Beocord 8802-V a wide range of features and facilities and, at the same time, ensures that operation was fast, straightforward and fool-proof. Automatic track adjustment meant that even well-worn tapes recorded on another machine were reproduced accurately – that was important if you intended to hire feature film cassettes for home screening.
Sound quality was also of the highest quality with a technique called Dynamic Sound Suppression, reducing distortion and unwanted noise to negligible levels.
Freeze-frame and picture search are useful features, especially for sports fans, and both could be operated by remote control.
Another outstanding benefit was the ease with which Beocord’s computer-controlled timer could be programmed to make up to 5 automatic recordings from any 5 TV channels within a 16-day period. Of course, you could also record one programme while watching another. The Beovision Video Terminal kept you in control of the whole system without moving more than a finger.
The Terminal was supplied as part of the TV; if you purchased Beocord V8802 separately, or with a manual Beovision TV, the Terminal had to be purchased as an optional accessory in order for you to obtain the extra convenience of remotely controlled video.
Programming Beocord V8802 to make unattended recordings was quick and easy, thanks to logical control systems and microcomputers. Simply key in the channel, the day and the start and stop times of the programme you wanted recording. Each instruction was confirmed on the illuminated communications panel. The microcomputer’s memory could store 5 such sets of instructions covering the period of 16 days ahead. You could even check your programming for accuracy and correct mistakes by operating the ‘clear’ button. When all the programmed recordings had been completed the machine rewound the tape ready for instant replay.
The 8-hour flip-over cassette was more convenient and economical to use than any other type then on the market. The cassettes were tamper-proof: it was impossible to damage them by touching any moving parts or the tape itself. A safety switch built into the cassette casing prevented the inadvertent erasure of recordings you wanted to keep.
