BeoCord 3500
BeoCord 3500
Beocord 3500 was part of Beosystem 3500, a budget-priced system for those who wanted to get onto the Bang & Olufsen bandwagon but could not afford, or did not want to have, the extra features that say, Beosystem 4500 had to offer. It included specifications such as Dolby B Noise Reduction and a Sendust head […]
It included specifications such as Dolby B Noise Reduction and a Sendust head for longer life of the recording/playback head, otherwise the features were identical to the Beocord 4500. Its only difference was the grey finish instead of its more expensive brother’s polished surfaces.
Type Number:4966, 4967, 4968
Release Date:1989, 1990, 1991, 1992, 1993
Colour / Finish:Black, Grey
Compact cassette: C46-C60-C90-C120
Recording system: HX PRO
Direct operation: Sensi touch
Tape transport system: Auto reverse
Search system: Track numbers
Noise reduction system: Dolby B NR
Tape switch: Auto ferro/chrom/metal
Tape head: Sendust
Wow and flutter DIN: 64 dB
Chrome Dolby B NR: >63 dB
Ferro Dolby B NR: >62 dB
Power supply:
4961 220V
4962 240V
4963 120V
4964 100V
4965 240V
Power consumption: 18 W
Dimensions W x H x D: 42 x 7 x 24.5cm
Weight: 4.5 kg
Connections: AudioLink
No downloads available.
