BeoCord 2400 (1969)
BeoCord 2400 (1969)
“What Advantages does your Beocord 2400 give you in the Form of Facilities, Performance and Reliability? Pressure diecast chassis for the mechanical section – provides a high degree of mechanical stability, assuring you that your Beocord 2400 is transport-proof. Silicon transistors in the fully transistorized amplifiers – a guarantee of highly stable operation, good signal-to-noise […]
“What Advantages does your Beocord 2400 give you in the Form of Facilities, Performance and Reliability? Pressure diecast chassis for the mechanical section – provides a high degree of mechanical stability, assuring you that your Beocord 2400 is transport-proof. Silicon transistors in the fully transistorized amplifiers – a guarantee of highly stable operation, good signal-to-noise ratio, minimum distortion, and low power consumption.
Separate tape heads for record and playback – permit you to monitor the tape while a recording is in progress. 4-track record and playback – permits maximum playing time for your tapes, both mono and stereo. Two-hand operating of record function – protects you against accidental erasure of tapes.
High degree of channel separation – in mono recordings, too, you will have good separation between the two channels. Twin-faders – make it easy for you to adjust for stereo balance on both record and playback.
Besides, the dual amplifier of your Beocord 2400 gives you the following interesting facilities: Sound on sound (part-song) recordings; adding echo to recordings; synchronous recordings such as pilot signals for slide projectors synchronized with sound reproduction; language laboratory: recording a foreign-language text on one track and conversation exercises synchronously on the other track.
Photo-stop feature – permits you to stop tape during programme scanning, if tape breaks, and at end of tape. Line jack – facilitates tape-copying from or to another Beocord; also permits connection to a large hi-fi system such as the BEOLAB 5000.
Your Beocord 2400 will operate as a hi-fi amplifier – the amplifier may be used without the motor running. It has separate inputs for microphone, gramophone, radio or FM/AM tuner and provision for connection of two pairs of stereo speakers. And your Beocord 2400 meets the minimum specifications for the DIN 45 500 Standards”
Release Date:1969, 1970, 1971, 1972
No specifications provided.
Language
Brochure
EN
BeoCord 2400 Brochure
User Guide
EN
BeoCord 2400 User Guide
User Guide
EN
BeoCord 2400 R-R User Guide
Service Manual
EN
4129, 4132, 4133, 4134, 4135, 4138
BeoCord 2400 Service Manual
Service Manual
EN
4134
BeoCord 2400 R-R Service Manual
Service Manual
EN
2663, 2665, 2667
