BeoCord 2000 (1983)
Designed as a perfect match, both physically and technically, for the Beomaster 2000, this advanced slim-line cassette deck was nonetheless a serious hi-fi product in its own right, combining a high-performance specification with supreme ease of operation. Despite its unassuming appearance, Beocord 2000 contained a full pay-load of advanced circuitry plus a few extra features rarely […]
Despite its unassuming appearance, Beocord 2000 contained a full pay-load of advanced circuitry plus a few extra features rarely found in cassette decks within this price frame. The primary controls – those concerned with tape movement – were totally electronic and designed on the Sensitouch principle. There were no knobs to turn or keys to press; a light fingertip touch was sufficient to activate any function.
Ferric, chrome or metal tapes could be used, and Dolby B noise reduction was included to ensure clean, hiss-free recordings. A clearly calibrated scale and input slider, together with large Peak Programme Meter, made it quick and easy to set accurate recording levels. These controls were placed adjacent to the cassette tray beneath a hinged lid which sprang open at a touch.
Beocord 2000’s built-in microcomputer made operation fast and foolproof. It was possible to switch directly between any and all tape transport modes without harming the tape, the mechanism or the motor. Microcomputer intelligence also opened the way for additional control functions that contributed in a very practical way to daily enjoyment of taped music.
A NEXT control allowed for easy track location (tape scan): one touch fast winds the tape to the next signal gap and plays the following track – automatically. So if you wanted to hear, for example, track number 5, just touch-and-wait four times and the place would be found for you. Similarly, you could repeat play-back of a favourite track up to five times with just a single touch. It’s such a convenient way of listening to exactly what you want, when you want.
Beocord 2000 had a socket for data-link connection to Beomaster 2000 so that direct switching was possible between Beomaster, Beogram and Beocord in the Beosystem 2000. The deck could also be data-linked to Beomaster 5000 or Beomaster 6000, when all tape functions could be operated via the receiver’s remote control system. Beocord 2000 could be made up as part of the Beosystem 2000, when linked together with other compatible Bang & Olufsen products. It was also part of Beosystem 3000 if that is how you wished to use it.
Compact cassette: C46-C60-C90-C120
Noise reduction system: Dolby B
Tape switch: manual ferro/chrom/metal
Wow and flutter DIN: 56 dB TDK-MA
Chrome Dolby B: > 56 dB TDK-SA
Ferro Dolby B: > 55 dB BASF LH I
Power supply:
2921 220
2922 240
2923 120
2925 240
Power consumption: max 20 W
Dimensions W x H x D 42 x 7 x 24.5cm (12.5cm with lid raised)
Weight 3.8 kg
Type | Language | Type | Date | Type | |
Instruction Manual | EN | BeoCord 2000 de luxe Instruction Manual | |||
User Guide | EN | BeoCord 2000K User Guide | |||
User Guide | EN | 2921, 2922, 2923, 2925 | 12-86 | BeoCord 2000 User Guide | |
Technical Guide | EN | BeoCord 2000 Technical Guide | |||
Service Manual | EN | 2921, 2922, 2923, 2925 | BeoCord 2000 Service Manual | ||
Circuit Diagram | EN | 265 | 09-64 | BeoCord 2000 Circuit Diagram | |
Service Manual | EN | 4119, 4120, 4121 | BeoCord 2000 de luxe T Service Manual | ||
Service Manual | EN | 4119, 4120, 4121 | BeoCord 2000 de luxe K Service Manual | ||
Circuit Diagram | EN | 5010 | 10-66 | BeoCord 2000 de luxe Circuit Diagram |
Photo Gallery
No gallery images.
