BeoCord 1600 (1981)
BeoCord 1600 (1981)
Beocord 1600 matched the Beomaster 1600 and Beogram 1600 both physically and technically. It combined high performance with easy, straightforward operation. Ferric, chrome or metal tapes could be used. The Sendust tape head, Dolby B Noise Reduction circuits and Peak Programme Meter all contributed to high quality recording and playback. You could switch between all modes of […]
Ferric, chrome or metal tapes could be used. The Sendust tape head, Dolby B Noise Reduction circuits and Peak Programme Meter all contributed to high quality recording and playback. You could switch between all modes of play without fear of tangling the tape or damaging the mechanism.
Type Number:2661, 2664
Release Date:1981, 1982, 1983
Designer:Jacob Jensen
Colour / Finish:Oak, Rosewood, Teak
Compact cassette: C46-C60-C90
Tape head: Sendust
Noise reduction: Dolby NR
Tape switch: Auto ferro/chrome
Wow and flutter DIN: <+/- 0.15%
Speed deviation: 66 dB
Signal-to-noise ratio chrome Dolby NR: >64 dB
Signal-to-noise ratio ferro Dolby NR: >62 dB
Power supply 2661 220V / 2664 120V
Power consumption 20 W
Dimensions W x H x D: 40 x 10 x 26cm
Weight 5 kg
Connections: Microphone DIN 0,3 mV / 33 kohms
Width 40cm, Height 10cm, depth 26cm
Language
Service Manual Prt1
EN
4207, 4205
BeoCord 1600 Service Manual Prt1
Service Manual Prt2
EN
4207, 4205
BeoCord 1600 Service Manual Prt2
Service Manual
EN
2661
