BeoCom 2500
BeoCom 2500
With BeoCom 2500 means of communication couldn’t be simpler. The display on the phone allows you see the caller’s number, the time of the call and even the caller’s name if it’s listed in the 121-number memory. And if you can’t get to the telephone, or just don’t want to be disturbed, BeoCom 2500 can […]
With BeoCom 2500 means of communication couldn’t be simpler. The display on the phone allows you see the caller’s number, the time of the call and even the caller’s name if it’s listed in the 121-number memory. And if you can’t get to the telephone, or just don’t want to be disturbed, BeoCom 2500 can act as a passive answering machine registering the numbers of the last 24 callers.
BeoCom 2500 also has optional volume control for recent B&O AV equipment and is available in a good choice of bright and bold colours.
BeoCom 2500 features:
Release Date:1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004
Designer:Martin Iseli
Dimensions W x H x D: 195 x 175 x 21mm
Weight: 600 g (handset 115 g)
Colours: Black, blue, green, yellow, grey, terracotta and red
Placement: Table
Caller ID with date and hour: 24 numbers and names
Memory (Phonebook): 121 numbers with names
Redial: 24 numbers and names
Extended redial: yes
Dialling of Caller ID number: yes
Indicator for line busy: yes
Indicator for unanswered calls: yes
Listening- in: yes
Volume control: yes
Microphone mute: yes
Display of call duration: yes
Ringer settings: yes
Contrast adjustment in display: yes
Supports supplementary services: yes
Option: Module for A/ V volume control: yes
Note: Caller ID and other services may need special subscriptions
No downloads available.
