BeoCenter 9500
BeoCenter 9500
The mirrored exterior of aluminium and smoked glass gave no hint of the power hidden beneath the surface of Beosystem 9500. Central to the concept was the AM/FM receiver. On the flanks, CD player and cassette recorder awaited their turn in the spotlight. When they were needed, a light touch on the display panel was […]
The mirrored exterior of aluminium and smoked glass gave no hint of the power hidden beneath the surface of Beosystem 9500. Central to the concept was the AM/FM receiver. On the flanks, CD player and cassette recorder awaited their turn in the spotlight. When they were needed, a light touch on the display panel was all that was required to make lids glide to the side giving immediate access to disc or cassette. The Beocenter was designed by Jacob Jensen and was the direct descendant of Beocenter 9000. The two models features here were superceded in 1994 by Beocenter 9300.
Simple logical operation
A light touch directly on Beocenter 9500 was all you needed to access its operation. The illuminated display led you logically through the programming and other functions always showing you what to do next. This ease and simplicity of use was the first impression you obtained of the music system. And equally easy to use was the optional remote control Beolink 1000 terminal.
Entertainment and information from three reliable sources
You could preset up to 20 FM and AM stations on the Beocenter 9500 receiver. And when you made your choice, search and fine tuning were completely automatic. Also, you could preset the receiver to switch on automatically to catch the news, or perhaps a favourite serial at just the right time. If you were out, the cassette recorder could be programmed to record and you could play back at your leisure.
You could also use the Beocenter 9500 receiver as a guaranteed alarm. In the event of a power failure during the night, the clock instantly switched to its own built-in batteries to ensure that you awoke at just the right time.
The CD player which accommodated both 12cm and 8cm compact discs was also ready for your commands. It gave you instant access to a specific track anywhere on the disc and allowed you to change the order in which the tracks were played, or to simply choose only those tracks you wished to listen to. Technology at its most convenient best. When used with Beogram 9500 the music system was known as Beosystem 9500.
Release Date:1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000
Designer:Jacob Jensen
Colour / Finish:Aluminium
Amplifier:
Long-term max. output power: IEC 2 x 80 watts / 8 ohms
Total harmonic distortion IHF: < 0.1 % & 30 watts 20 – 20,000 Hz
Dynamic headroom 1 dB: / 8 ohms
Intermodulation IHF: < 0.1 %
Bass control at 40 Hz: +/- 10 dB
Treble control at 12,500 Hz: +/- 8 dB
Tape recorder:
Compact cassette C46 – C120
Recording system HX PRO
Tape head Sendust
Wow and flutter DIN 64 dB, C: >73 dB
Chrome Dolby NR B:>65 dB, C: >74 dB
Ferro Dolby NR B:>63 dB, C: >72 dB
Power supply: 110 – 130 – 220 – 240 voltage switch
Power consumption Max. 200 W
Dimensions W x H x D 76 x 11 x 34cm
Weight 14 kg
Tuner:
FM range: 76 – 90 MHz (Type 2509, 2513)
87.5 – 108 MHz (Type 2506, 2508, 2510, 2511, 2512, 2514)
LW range 2506, 2511: 150 – 350 kHz
MW range 2506, 2508, 2509, 2510, 2511, 2512, 2513, 2514520 – 610 kHz
Compact disc player:
Frequency range 3 – 20,000 Hz +/- 0.3 dB
Signal-to-noise ratio > 100 dB / 110 dB A-weighted
Dynamic range > 96 dB
Harmonic distortion 0.0025 % at 0 dB
0.0025 % at -20 dB
Channel separation > 101 dB
Converter system 2 x 16 bit, 4 x oversampling
Low pass filter analogue Bessel
Connections: Beocord Tape 1 Built-in
Beocord Tape 2 7-pin DIN, Datalink
Beogram CD Built-in
Beogram LP 7-pin DIN, Datalink
BeoLab 2 x Power Link
Beovox 4-pin DIN
Beovision 7-pin DIN, Datalink
Link compatibility: Master Control Link
Language
Language
User Guide
EN
EN
BeoCenter 9500 User Guide
Setup Guide
EN
EN
BeoCenter 9500 Setup Guide
Door Cord
Multi
Multi
BeoCenter 9500 Doory Cord
Service Manual
Multi
BeoCenter 9500
Service Manual
Service Manual Corrections
Multi
BeoCenter 9500
BeoCenter displays "CODE"
This usually happens if you have replaced the S/W or the lithium battery has been replaced or needs replacing.
Fix the battery or RAM and then:
BeoCenter 9500 - hums
B&O recognise the problem and came up with a particularly high tech approach.
Special feet! Part number 3103347 !!
Clearly there will still be some hum but it does reduce a lot.
BeoCenter 9500 - Speakers make noises when switching on/off
The DC supply voltage has not stabilised before the signal is sent to the speakers.
There is a service kit available if this bothers you though, and the later BeoSounds actually have a longer delay before the signal is sent so make no noise!
