BeoCenter 2100
BeoCenter 2100
Beocenter 2100 – three variations and a one-finger exercise Beocenters 2200, 2100 and 4000 – each with a totally distinctive style but sharing the unmistakeable themes of Bang & Olufsen quality and simplicity. If you loved true hi-fi but you weren’t a record fan, then Bang & Olufsen ‘had your radio perfectly taped’! Beocenter 2100 had all […]
If you loved true hi-fi but you weren’t a record fan, then Bang & Olufsen ‘had your radio perfectly taped’! Beocenter 2100 had all the features of Beocenter 2200 but without the record deck so that it took up even more of a conveniently small space.
Beovox X25 loudspeakers were the offered choice but you could equally mix and match the Beocenter with any other Bang & Olufsen speaker on the market at that time. When linked with Beovox X25 loudspeakers, the combined system was known as Beosystem 2100. A recommended record deck to complement your system would be either the Beogram RX2 or TX2.
Type Number:2441, 2442, 2449
Release Date:1985, 1986, 1987, 1988
Designer:David Lewis
Colour / Finish:Aluminium, Black
Power output RMS DIN/IEC 2 x 25 watts / 4 ohms
2 x 20 watts / 8 ohms
Harmonic distortion < 0.2 %
Intermodulation < 0.4 %
Frequency range 1.5 dB 20 – 20,000 Hz
Signal-to-noise ratio > 78 dB
Channel separation 1000 kHz > 50 dB
Tuner:
FM frequency range 87.5 – 108 MHz
LW frequency range 147 – 350 kHz
MW frequency range 520 – 1610 kHz Tape deck:
Compact cassette C46 – C60 – C90 – C120
Wow and flutter < +/- 0.2 %
Frequency range 30 – 15,000 Hz
Signal-to-noise ratio CCIR/ARM
Metal Dolby NR > 67 dB TDK-MA
Chrome Dolby NR > 65 dB TDK-SA
Ferro Dolby NR > 63 dB BASF LH I
Metal > 59 dB
Chrome > 57 dB
Power supply:
2441: 220V
2442: 240V
2449: 220V
Power consumption 25 – 140 W
Dimensions W x H x D: 64 x 9.5 x 33cm
Weight 10 kg
Language
Service Manual
EN
BeoCenter 2100 Service Manual
