Wiring Diagrams
All wiring diagrams to plugs and sockets are shown from the soldering side.
MasterLink cable
Note: For older-type ML cable, the colour coding is slightly different. This image refers to current ML cable.
Master Control Link cable
DataLink Cable 7/7 pin A/V Cable
21-pin A/V cable with RGB connection:
Receiver cable
Infra-red eye wiring
Headphones
B&O Motorised Stand
Note that the technical specifications for the motorised stand changed from Product ref. MX6/7 to MX8. Newer models also have a different stand connection
RGBHV Cable (15-Pin D-SUB)
15-Pin D-SUB
Power Link cable with wire for display, also for BeoLab 5
Power Link cable 8/8 pin
(Note: On BeoLab3 there is a blue wire (pin 7) in addition to the wires shown here on the PowerLink diagram.  This appears to be a voltage reference for the speakers, and with a single three core wire + screen feeding both speakers, this needs to be connected to the screen.
Failure to connect this pin does not have too much of an effect on the system -UNLESS- you connect up something like a PC2 which ties the stereo to Earth potential through the MasterLink cable, and without the “blue reference” the speaker inputs can float to around 100V above Earth and cause interference between the speakers and the 3000, manifesting as a quiet buzzing noise in the Lab3s. (I rather suspect there was actually an impact on sound quality from no Blue connection but cannot measure it) – Stephen Lewis)
Power Link cable
Speaker Link cable
Audio Aux Link / Power Link connections
Aux Link cable
white data
blue left channel input
green right channel input
shield ground
red right channel output
yellow left channel output
black data ground
male to male, using unterminated cable number 6250265 and plug number 7220688 or 7220701.  For connection between video system and audio system. Maximum length: 100m
Aux Link/Datalink cable
white data
shield ground
black data ground
male plug to wall plate, using unterminated cable number 6250265.  Use male plug number 7220688 or 7220701 and an 8-pin wall plate number 7210473.  Used for connecting local sources when MCL 2AV is concealed
Aux Link Wall Plate
  Audio System Video System
white data data
blue left channel input left channel output
green right channel input right channel output
shield ground ground
red right channel output right channel input
yellow left channel output left channel ground
black data ground data ground
wall plate to wall plate, using unterminated cable number 6250265 and two 8-pin wall plates number 7210473.  Used for connection between audio and video systems within the wall wiring
Switch for deactivation of MCL
Audio Aux Link
MCL cable from audio systems to terminal
green right channel hot
brown right channel ground
pink DC supply 7.5 – 8.5 VDC
yellow left channel hot
grey left channel ground
white data
shield data and ground DC ground
MCL cable from audio systems to terminal strip in MCL2 relay box. NOTE: Use pre-made MCL cables for connection to the audio system whenever possible
MCL cable, 2 x 3-pin MCL to 8-pin DIN plug
white data
shield data and DC ground
MCL cable, 2 x 3-pin MCL to 8-pin DIN plug. For connection between audio systems and link system via an 8-pin wall plate.  Use pre-made MCL cable for connection to the audio system if at all possible
MCL cable between 8-pin DIN wall plate
white data
MCL cable between 8-pin DIN wall plate and MCL terminal strip.  For connection between audio system and link system via an 8-pin wall plate
Speaker link cable from audio system or MCL to 4-pin wall plate
green or brown signal hot
shield signal ground
white display data
shield data ground
Speaker link cable from audio system or MCL to 4-pin wall plate using speaker plug number 7220040. Use unterminated link cable number 6250246 or 6250267
PowerLink cable, male to male
brown left audio signal
green right audio signal
shield: brown/green left/right ground
grey on/off
yellow on/off
pink APHC
white data
shield: white data ground
PowerLink cable, male to male, using unterminated cable number 6250277 and plug number 7220345.  Maximum length 100m
PowerLink cable, male to female (extension)
brown
green
shield: brown/green
grey
yellow
pink
white
shield: white
PowerLink cable, male to female (extension) using unterminated cable number 6250277, male 8-pin plug number 7220345 and female 8-pin plug number 7220235 or 8-pin DIN wall plate number 7210473.  Maximum length component to component: 100m
PowerLink cable, female to female
brown
green
shield: brown/green
grey
yellow
pink
white
shield: white
PowerLink cable, female to female, using unterminated cable number 6250277 and two female 8-pin DIN plugs number 7220235 or two 8-pin DIN wall plates number 7210473
PowerLink 1 & 2
Using a non-B&O sub-woofer
his circuit is designed to use a non-B&O sub-woofer or amplifier with PowerLink sockets.
It’s easy to built and at low cost. In fact that the 5 V DC from the PowerLink socket on pen 4 can’t activate a relay directly you will need a circuit like this.
Parts which I’ve used are easy to buy at electronic shops. You need in total:
1 AC/DC Adaptor 12 V DC
1 IC LM 7806
2 Caps 100Nf 63V
1 Diode 1N4148
1 Resistor 2K2
1 Transistor BC 338
1 Relay 6V DC
Connection of the circuit is as follows:
Connect the adaptor to the 12V and earth of the circuit, connect pin 4 from the PowerLink to the 5V DC PowerLink in of the circuit. When switching on the B&O the relays will switch and connect the 230V AC line into the amp you use. That’s it. For heavy amps you can let the relay switch on a second heavy-duty relay, which will switch on the power line.
