LC2 Light Controller
A part of the Bang & Olufsen complete home entertainment solution is the light control system which allows for the adjustment of light-settings of a single lamp, room or entire house with a Beolink® remote control. You can also program local and global light-settings so that when you press ‘LIGHT’ and ‘1’ on the relevant […]
You can also program local and global light-settings so that when you press ‘LIGHT’ and ‘1’ on the relevant remote control all the lights in the room adjust to their preset lux-settings which are stored in memory-location ‘1’. Nine local light settings can be stored with the dimming of each light unit being made individually.
Type Number:2130, 2131
Release Date:1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005, 2006
Colour / Finish:White
Operation Sensi-touch
Recommended terminal Beo4, Beolink 1000 MK2, MK3, Beolink 5000, Beolink 7000
Finish: white
Power supply: 220 - 240 V
Power frequency:50 Hz +/- 5 %
Standby consumption: 0.7 watts RMS Weight:195g (with wall mounting, 210g)
Dimension W x H x D: 98 x 52 x 98cm
Control Principle: Phase-cutting (TRIAC)
Connections: Standard filament bulbs 40 - 300 watts
High-voltage halogen bulbs:220 - 240V 40 - 300 watts
Low-voltage halogen bulbs 220 - 240V transformer 40 - 300 watts
Low energy bulbs (on/off): 0 - 100 watts
Fluorescent tubes (on/off): 0 - 100 watts
Language
Date
User Guide
EN
LC2 User Guide
Service Manual
EN
2130, 2131
LC2 Service Manual
