LG update to newer WebOS – question?
Viewing 9 posts - 1 through 9 (of 9 total)
  • #32264
    Millemissen
      • Flensborg————Danmark
      • Topics Started 21
      • Total Posts 1,025
      Now LG is rolling out the update of the OS for earlier tv models.
      My C2 was offered the update to WebOS23, but I am not sure, that I want it.
      I hardly use the UI of the tv – just the tuner occasionally.
      Main source is an ATV, a CC dongle and the Blu Ray player (all connected to the BST).
      Does it makes sense to upgrade – any downsides?
      What is your experience, if any?
      patcherley
      GOLD Member
        • Hampshire
        • Topics Started 12
        • Total Posts 55
        I have updated my Eclipse, apart from the UI haven’t noticed any real difference, not sure I really like the new UI. But again I also don’t use the UI much at all, it I watch a TV programme I go straight there with the BeoRemoteOne short cut button.
        #32280
        Sandyb
          • Topics Started 1
          • Total Posts 372
          I updated my panels – no issues.
          Like most I barely use the webOS UI – though there is now the option to have the screen timeout / screen saver as a simple information window – clock and weather.
          I actually enabled this – largely as the post update wizard shows it to you, so it’s a few clicks to enable – and actually dont mind it.  Just a black screen with a simple clock on it.
          Otherwise, no issues with the update.
          #32289
          Sandyb
            • Topics Started 1
            • Total Posts 372
            Just to add….while I did update both my rooms to the new webOS, I hadn’t used my main living room Theatre/LG setup after updating.
            While my standalone bedroom Theatre/LG was fine with the new webOS, my living room setup seemed to lose the LG integration – example being all the internal sources were gone from the BR1 etc etc.
            So I had to re-establish the LG/B&O webOS integration – which was a bit of a messy process, took a few attempts, but back to normal now.
            Bit odd, I only had to do this on one of my Theatre setups.
            #32291
            Millemissen
              • Topics Started 21
              • Total Posts 1,025
              Thanks for the update
              ‘….bit of a messy processtook a few attempts.’
              Which were these attempts – what did you have to do……..just in case?
              Sandyb
                • Topics Started 1
                • Total Posts 372
                Guess its the same as when you first setup a BST/LG from new.
                i.e. the B&O app page for the BST has the “Enable LG/B&O app integration” type banner / message.
                The difference (compared to box fresh and new) was that my LG already had the B&O webOS app installed. So, what to do?
                I forced the issue a bit, by deleting the webOS app and re-installing it.  The B&O app says to restart the TV when the app is installed, which I did but “integration” didnt take hold / re-establish itself.  I went round this loop a couple of times, and  then just rebooted the Theatre, which seemed to re-establish the integration.
                I guess, once the integration had disappeared initially, I should have perhaps just rebooted the Theatre. Not sure deleting/re-installing the B&O webOS app process was necessary – but who knows.
                Anyway, all good now.
                #32300
                Millemissen
                  • Topics Started 21
                  • Total Posts 1,025
                  Ok – I think I’d better turn off the update.
                  Not in the mood for such a ‘messy process’.
                  My combo run just fine right now.
                  By the way – the tv did not offer the update yesterday by turning on.
                  Maybe it only happens a couple of times ?
                  Sandyb
                    • Topics Started 1
                    • Total Posts 372
                    Another note to those who have updated webOS.
                    I noticed, after updating, that when using internal webOS apps the LG was passing PCM to the Theatre.  Observed this using Disney+ and Apple TV+ apps.
                    Never seen this before – prior to the update, internal apps were always passing bitstream to the Theatre.
                    Never looked at the Sound settings of the LG before, but when I did (Sound/Advanced Settings / Digital Sound Output) it was showng the Digital Sound Output set as PCM.  I reset it, in this menu, to Pass Through.    Everything then shows as expected (DD / DD+ / Atmos etc) in the B&O app.
                    What surprised me was that – using an Apple TV+ Atmos show – using Pass Through and allowing the Theatre to do its thing sounded a good deal better than when the LG was set to PCM.
                    Not a scientific sample I grant you, but did surprise me. Not relevant to those who only use an Apple TV box
                    Anyway, thought I’d share.
                    #32354
                    Severed_hand_of_skywalker
                      • Toronto, Canada
                      • Topics Started 8
                      • Total Posts 211
                      I did mine first day on My G2. No issues. No real point though if you don’t use the TV os. I sure don’t use it, still terrible.
