BeoRemote One
  • This topic has 12 replies, 3 voices, and was last updated 1 year ago by ABO.
Viewing 13 posts - 1 through 13 (of 13 total)
  • #14915
    ABO
      • Sweden
      • Topics Started 1
      • Total Posts 8
      Hi. I have an BeoRemote One (New) there the display has begin to loosen from the upper corner. Is there anybody who can tell if the display is attached with some kind of tape or glue? Is it possible to loosen the whole display and and attache it again with double sided tape or some kind of glue? Very grateful for any kind of tips.
      Regard ABO
      #14917
      Guy
        • Warwickshire, UK
        • Topics Started 14
        • Total Posts 1,235
        I can’t view the attachment because it comes up as a heic file.  Can you ‘insert image’ instead using the picture icon above the visual box that you type in?  Many thanks!
        #14920
        ABO
          • Sweden
          • Topics Started 1
          • Total Posts 8
          I don’t know if this works but I’ll try.
          #14942
          Guy
            • Warwickshire, UK
            • Topics Started 14
            • Total Posts 1,235
            Like this!
            8C1A6BC0-7173-4974-9EE6-C271FD812560-scaled
            #14945
            Millemissen
              • Flensborg————Danmark
              • Topics Started 21
              • Total Posts 1,025
              Known issue – please contact your dealer
              Start at 5:00
              ABO
                • Sweden
                • Topics Started 1
                • Total Posts 8
                Thank for the tip
                //ABO
                #14993
                ABO
                  • Sweden
                  • Topics Started 1
                  • Total Posts 8
                  Hi. My guarantee is no longer valid so can I use some glue to repair it by my self?
                  Regards ABO.
                  #14994
                  Millemissen
                    • Topics Started 21
                    • Total Posts 1,025
                    I’d ask my dealer anyway.
                    This is not supposed to be so, even after garantie.
                    How old is it – has you had any fluid spilled on it or so?
                    Also, you could buy a new insert/inlay and reuse the housing, if you don’t have success with glue.
                    ABO
                      • Sweden
                      • Topics Started 1
                      • Total Posts 8
                      It was buyed from a serious dealer who buy and sells preowned Beo products. This remote was newer used according him. I received it with original package and plastic film on the display. No fluid has never spilled on it, I am very careful with my products. The display started to loosen after 2 days after I received it.
                      ABO
                      #15057
                      ABO
                        • Sweden
                        • Topics Started 1
                        • Total Posts 8
                        Hi B&O friends. I have just fixed the problem with the loosen display on Beoremote One.
                        It is attached with doublesided thin tape.
                        ABO
                        #15064
                        Guy
                          • Warwickshire, UK
                          • Topics Started 14
                          • Total Posts 1,235
                          Excellent – thanks for letting us know how you fixed it, and with a photo!
                          #15138
                          ABO
                            • Sweden
                            • Topics Started 1
                            • Total Posts 8
                            Hi. What kind of tools do I have to get (cable,software etc) to program my Beo6 remote. I bought it used with factory setting. Nothing happens when I touch the the display.
                            I’m going to use it with Beosound 3000.
                            // ABO
                            #21916
                            ABO
                              • Sweden
                              • Topics Started 1
                              • Total Posts 8
                              Hi folks. My Halo looses connection to Wi-Fi shortly after installation. I have tryed with factory settings and reinstall several times but the problem remains. My other B&O products Core, Stage, Beosound1 have no problems to keep connection. I have been in touch with Beo support several times with various kind of solutions but nothing helps. Is there anybody who has a clue what it can be?.
                              Regards ABO.
