Beomaster 4400 FM stereo indicator is permanently lit
Viewing 8 posts - 1 through 8 (of 8 total)
  • #23805
    webesteen
      • Topics Started 2
      • Total Posts 9
      On my beomaster 4400 the fm stereo indicator LED lights up when the beomaster is turned on no matter whether it is turned on with Phono, tape one, tape two or any of the FM buttons. I have tried to turn 3C8 as describen in the sevice manual but nothing happens.
      #23904
      webesteen
        • Topics Started 2
        • Total Posts 9
        Hallo hallo er her nogen? Anybody here? Jeg kan høre ekkoet 🙁
        #23906
        Dillen
          • Topics Started 3
          • Total Posts 587
          Unless a wire is shorting to something, which would be very obvious, it can almost only be a case of a bad stereo decoder IC.
          #23926
          webesteen
            • Topics Started 2
            • Total Posts 9
            Thank you Martin :))  I have been looking for a short or wrong connection as I have changed both the radicator and the LED and also the on/off switch. I will look again and perhaps change the stereo decoder card with a spare one that I have. Thank you again for answering.
            Erling Steen
            #23974
            webesteen
              • Topics Started 2
              • Total Posts 9
              Solved; a classic:  Tiny little piece of solder between two legs of the stereo decoder IC
              Thank you Matin
              Regards
              Erling
              #23987
              Dillen
                • Topics Started 3
                • Total Posts 587
                Good job!
                #23988
                mexking
                  • Mexico city
                  • Topics Started 1
                  • Total Posts 47
                  These failures are difficult to find, one are always looking for component failures and at last it turns out to be something simple you dont think about, (except for Martin who have seen it all) good job, jeg er ekkoet
                  #24004
                  webesteen
                    • Topics Started 2
                    • Total Posts 9
                    Martin suggested a short or the IC so I took a look at the IC and found a short 🙂 Its a reminder; “always look for small pieces of solder”
