Beogram 5500 – buzzing issue
  • #30903
    Stevendalton
      • Topics Started 1
      • Total Posts 2
      Hi, I have a Beogram 5500 which I’ve connected to my B&O Stage through the line in. I get an awful buzzing when anything is playing.
      setup is Beogram 5pin to rca line in on a pre amp
      line out rca to 3.5mm jack which goes to the stage.
      any suggestions as it’s driving me crazy.
      thanks in advance
      Steven
      #30919
      Mark-sf
        • Topics Started 0
        • Total Posts 294
        You mention a preamp but don’t mention which one and whether you are using the proper Phone DIN cable to it. This cable has double screening and is a requirement to prevent hum and buzz.
        #30920
        Stevendalton
          • Topics Started 1
          • Total Posts 2
          Thanks for replying.
          this is what I’ve got going into the amp from the Beogram cable:
          5 Pin DIN Female to 2 RCA Male… https://www.amazon.co.uk/dp/B0BVN17132?ref=ppx_pop_mob_ap_share
          this is the amp:
          Pro-Ject Phono Box (DC), MM/MC… https://www.amazon.co.uk/dp/B007DB5I60?ref=ppx_pop_mob_ap_share
          any help / advice would be greatly appreciated
          Steven
          #30931
          987nick
            • Topics Started 6
            • Total Posts 17
            I think you need a cable with a proper earthing from the turntable.  The connector you’ve bought won’t have this.
            You can get one at Sounds Heavenly.  Or, Beocable on eBay do one.
            I’d be interested how you get on as I’m intending to connect my Beogram 3300 to an amp using the Pro-ject phono box with the Beocable connector.  I’m just waiting to buy an MMC4 cartridge.
            #30950
            Mark-sf
              • Topics Started 0
              • Total Posts 294
              If you have the original phono DIN cable marked with a PH then B&O used to have DIN->RCA adaptor that had an external ground wire which is needed. If you can find that then a special internally grounded one such as https://soundsheavenly.com/beogram-record-players/14-2244-beogram-to-non-bo-device-as-used-on-beogram-4000c-phono-pre-amp-receiver-amplifier-etc-bo-ref-6271348.html#/2-length-1m/60-grounding-internal_ground_link will work.
