Reply To: Beo4 Remote Button Mischief
#1718
Guy
    • Warwickshire, UK
    • Topics Started 14
    • Total Posts 1,235
    The symptoms do indeed sound like a contact foil fault.  However, the non working buttons share two of the same foil/PCB contact points (R1, R4 in the manual) so perhaps the connection between the keypad foil and PCB is dirty, or misaligned.  Try removing the clip, cleaning and re-assembly.
    Otherwise sometime the PCBs do sometimes go wrong; I have had a couple ☹
